Temperature sensor from Analogue to Digital
I am currently doing a mini-project on temperature sensor using 8051 micro-controller.
The 8051 micro-controller will receive 8bit temperature data from Analogue-to-Digital Converter which is connected to a temperature sensor(eg. LM35)
I have a problem in translating the 8bit data from ADC to a temperature reading (eg. 38 celcius)in keil. I hope to understand the structure or the procedure in carrying out this step. Thank you!
  • The data sheet
    http://www.national.com/pf/LM/LM35.html
    says that the part produces a linear +10 mV per degree C. So, take the voltage measurement from the ADC and divide to get a temperature. You might need to add a constant to account for the "zero" point of the device.
    Or, to look at it another way, you have an 8-bit ADC, which 8 bits have to cover the whole temperature range. So you could just scale the 0-255 value to the range of temperatures for the LM35.
    It should be a nice, simple, one-line calculation. What problem are you having, exactly?
  • Thank you for the overview, I appreciate it. Now I am having a problem on how to convert the incoming 8-bit data from ADC to a temperature reading by using the keil Software. Futhermore, I am using AT89C52 micro-controller.
    I am aware that 8-bit data would have 256 combination from 0000 0000 to 1111 1111. Each step from 0000 0000 to 0000 0001 contribute to a certain degree C. However, how can i programme to allow the incoming binary to becoming a temperature reading appearing on the keil?
  • how can i programme to allow the incoming binary to becoming a temperature reading appearing on the keil?
    How about using an array? For example:
    float temp_table [256] =
    You could fill the array with the temperature readings for each A/D value from 0 to 255. Then, your program could read from the array whenever it needed a temperature for an A/D reading.
    Personally, I would take a close look at my high-school algebra book and not use a table (certainly not a floating-point table).
    Jon
  • "Each step from 0000 0000 to 0000 0001 contribute to a certain degree C."
    Exactly - so all you need to do is apply the scale factor that relates the 1-bit step to a certain degree C.
    You may also need to add an offset to account for the Celsius temperature corresonding to the 8-bit binay 0000 0000.
    Assuming it's linear, it's your good old y = mx + c
    Note that this has nothing specifically to do with Keil - the principle is the same whatever tools you use, and whatever language, from whatever vendor!
    Try thinking about how you'd do it by hand!
  • Perhaps you are confused by the fact that there are actually two scale factors involved here:
    1. As Drew pointed out, the sensor produces a linear +10 mV per degree C.
    So that's an easy one - you can easily get from mV to degrees C, can't you?
    2. There's the scale factor of the ADC:
    * what voltage (and, thus, temperature) does the value 0x00 represent?
    * what voltage (and, thus, temperature) does the value 0xFF represent?
    From there you can easily deduce what voltage step (and, thus, temperature step) produces a 1-bit step in the ADC value (eg, 0x00 to 0x01)
    "Futhermore, I am using AT89C52 micro-controller."
    Again, that's irrelevant - the principle is the same irrespective of what you run it on!
  • thanks! by the way, which port would i acquire the 8bit data because the AT89C52 have 4 port?
    Futhermore, i have set aside P0 to LCD display and P1 to keypad.
  • "which port would i acquire the 8bit data because the AT89C52 have 4 port?"
    You choose!
  • Below is the C prog. I notice that the problem is lies with "OPORT = instr;"
    because it suppose to move what is in instr into OPORT which is in Xdata at location 0000h but it did not.
    #include <reg51.h>
    void delay5ms(void);
    void delay1ms(void);
    void lcdWriteInstrReg(char instr);
    void lcdInit(void);
    void lcdClrScr(void);
    char xdata OPORT _at_ 0x0000;
    sbit pinRW = P3^3;
    sbit pinRS = P3^4;
    sbit pinE = P3^5;
    void main(void)
    lcdInit();
    while(1);
    }//end main
    OPORT = instr; //o/p to D0-D7
    pinRW = 0; //write
    pinRS = 0; //RS=0 for instr Reg
    pinE = 0;
    pinE = 1;
    pinE = 0;
    void lcdInit(void)
    delay5ms();
    delay5ms();
    delay5ms();
    delay5ms();
    lcdWriteInstrReg(0x38);
    delayms();
    delay1ms();
    delay1ms();
    lcdWriteInstrReg(0x06);
    delay1ms();
    lcdWriteInstrReg(0x0f);
    delay1ms();
    lcdClrScr();
    lcdWriteInstrReg(0x01);
    delay1ms();
    delay1ms();
  • void main(void)
    char ebit,ans;
    ebit = 0x01;
    ans = ebit*(100/256);
    how can i display the value in ans on LCD
    void lcdPutStr (char *string)
    char i;
    i=0;
    while(string[i])
    lcdPutCh (string[i++]);
    this is the program segment for putting the characters into LCD.
