Hallo, now I have another serius problem. For your information, I use: Cx51 Ver 7.06 Philips / 89C669 An expression which involves a far variable does not produce correct result. Here is my test program:
#include <Philips\reg51m.h> unsigned int result ; unsigned int v = 25 ; far unsigned int v2 = 25 ; unsigned int f1 (unsigned char N) { return((v * N * 2) + (v / 10)) ; } unsigned int f2 (unsigned char N) { return((v2 * N * 2) + (v2 / 10)) ; } void main () { result = f1(0) ;// expected 2 result = f1(1) ;// expected 52 result = f1(2) ;// expected 102 result = f2(0) ;// expected 2 (received 2) result = f2(1) ;// expected 52 (received 2) result = f2(2) ;// expected 102 (received 2) }
You may want to contact support directly on this. See the 4th bullet item. http://www.keil.com/forum/terms.asp
Hallo, Thank you. But how to inform a bug? mk
Send email to: support.intl at keil.com Stefan
