Hello, I'm relatively new in using Keil C166 development system. First tests are successfully so far using the Keil MCB167NET board. As a long time C programmer I'm interested in the quality of generated code. I noticed that the generated code sometimes has unnecessary code lines that I thought an optimizer should be able to find. Here is a example:
#include <C167CS.H> #include "comtype.h" #include "timer.h" void timer_init() { struct T01_CON { uint T0L :3; uint T0M :1; uint un00:2; uint T0R :1; uint un01:1; uint T1L :3; uint T1M :1; uint un10:2; uint T1R :1; uint un11:1; }; union { struct T01_CON tcon; uint reg; } u; u.reg = T01CON; u.tcon.T0L = 2; // FCPU / 2^(3+T0L) = 2 µs at 16MHz u.tcon.T0M = 0; // Timer Mode u.tcon.T0R = 1; // run Timer T01CON = u.reg; }//timer_init
; FUNCTION timer_init (BEGIN RMASK = @0x4030) 0000 2802 SUB R0,#02H 0002 F2F550FF MOV R5,T01CON 0006 B850 MOV [R0],R5 ; u 0008 A840 MOV R4,[R0] ; u 000A 0AF54F42 BFLDL R5,#04FH,#042H 000E B850 MOV [R0],R5 ; u 0010 A840 MOV R4,[R0] ; u 0012 F6F550FF MOV T01CON,R5 0016 0802 ADD R0,#02H 0018 CB00 RET ; FUNCTION timer_init (END RMASK = @0x4030)
It is typical to directly modify the bits in an SFR. For example, the following:
void timer_init (void) { T01CON &= ~(0x0007 | 0x0008 | 0x0040); T01CON |= (0x0002 | 0x0040); }
0000 66A8B0FF AND T01CON,#0FFB0H 0004 76A84200 OR T01CON,#042H 0008 CB00 RET
Hi Heinz, I made a similar observation. Consider this example:
int a, b, c, d; void main(void) { a = c / d; b = c % d; } 0000 F2F70000 R MOV R7,d 0004 F2F60200 R MOV R6,c 0008 F6F60EFE MOV MDL,R6 000C 4B77 DIV R7 000E F6070600 R MOV a,MDL 0012 F6F60EFE MOV MDL,R6 0016 4B77 DIV R7 0018 F2F40CFE MOV R4,MDH 001C F2F50EFE MOV R5,MDL 0020 F6F40400 R MOV b,R4 0024 CB00 RET
MOV R6,d MOV MDL,c DIV R6 MOV a,MDL MOV b,MDH RET
maybe we are spoilt by modern compilers like gcc GCC for the C167 generated the following code for the example you provided.
.globl _main _main: mov [-r0],r1 mov r1,r0 mov [-r0],r8 mov r4,_c mov r5,_d mov MDL,r4 div r5 mov r4,MDL mov _a,r4 mov r4,_c mov r5,_d mov MDL,r4 div r5 mov r4,MDH mov _b,r4 L1: mov r8,[r0+] mov r1,[r0+] jmpi cc_UC,[r8]
Well, it tells something about those who did the porting. We all know that the C166 port of GCC was not merged with the official GCC code tree so it didn't see as much development as it could have. When I mentioned GCC, I was mostly referring to GCC for x86. I agree, Keil's C compiler for the C166 must be the best in the market. But it can be better.
Well, it tells something about those who did the porting. We all know that the C166 port of GCC was not merged with the official GCC code tree so it didn't see as much development as it could have. When I mentioned GCC, I was mostly referring to GCC for x86. Actually, the port I used is a commercial GCC implementation that is supposedly better than the "official" (is there such a thing) GCC 166 port. The problem that you pose is interesting in that you generate a dividend and remainder (in adjacent statements) for the same quotient and divisor. So, if the CPU's DIV instruction generates a dividend and a remainder, only 1 DIV instruction is required. However, I'm not sure what kind of general optimization that would be (dividene/remainder coloring???). I contacted one of the compiler developer's at Microsoft to see if they performed this optimization and it appears that they do. After a lengthy discussion, I think that the added this optimization to improve some kind of Windows or PC benchmarks. A question that needs to be answered is, how often do developer's need a dividend and remainder from the same quotient and divisor? If the answer is often, then perhaps we need to consider this optimization (we focus our efforts on improvements that benefit the greatest number of users). Jon
A question that needs to be answered is, how often do developers need a dividend and remainder from the same quotient and divisor? My two cents: pretty often! For one example, it's very common for me to run into a situation where I have some sort of table in a series of registers, where the individual items are less than the full register width. Let's say you have 16 items, two bits wide, 4 items per byte, thus taking up 4 bytes of address space in total, thus:
addr item num ---- -------- 0000: 3 2 1 0 0001: 7 6 5 4 0002: b a 9 8 0003: f d e c
Item GetItem (int n) { index = n / ItemsPerWord; offset = n % ItemsPerWord; return (*(base + index) >> offset) & mask; }
Hello Jon, It is typical to directly modify the bits in an SFR. For example, the following: void timer_init (void) { T01CON &= ~(0x0007 | 0x0008 | 0x0040); T01CON |= (0x0002 | 0x0040); } Yes, I changed it in a similar way now. Your hint with the interrupt in between read and write wouldn't be a problem as this initialization only happens ones at startup. It can be a problem in other situations, however. My original idea was to have field names in the sfr as found in the device data sheet. - Heinz
I agree, Keil's C compiler for the C166 must be the best in the market. But it can be better. That's what I wanted to say ;-) - Heinz
The problem that you pose is interesting in that you generate a dividend and remainder (in adjacent statements) for the same quotient and divisor. So, if the CPU's DIV instruction generates a dividend and a remainder, only 1 DIV instruction is required. However, I'm not sure what kind of general optimization that would be (dividene/remainder coloring???). Maybe as a extension of common subexpression optimization? Or, as I remember from the compiler writing course, a peephole optimization on the generated code. Such a optimizer should be able to analyze code sequences with no jumps in/out. So the flow graph must still be used. - Heinz
