I am trying to setup keil project for infineon chip. I am using Hitex SLE90 Emulator for debugging purpose. In order to set "Hitex SLE90 emulator" for debugging, I need to go to "Options" ==> "Debug" ==> "Use SLE90 Emulator".
But I am getting pop up stating following error - ========================================================================= Error: cannot load driver 'C:\Program Files(x86)\Keil_Arm_infineonSlc14\ARM\Hitex\AGDIAdapter_GET90.dll'
Possible Reasons: - Driver dll could not be found in specified path. - Driver dll requires additions dll which are not installed. - Required hardware drivers are not installed. =========================================================================
I am using KeilArm SDK V5.17. Please help how to resolve the error.
Does the file exist, have you tried any of the described remedies? What version of the driver are you using? Have you copied most recent installed drivers and support files to the directory Keil is using?
What does your IT dept suggest?
