I am using an calloc routine and it is giving me an address of zero even though I have initialized the memory with init_mempool (0x0600, 0x02FF); Can you help? What is happening and what should I do about it? Sean
the '51 is NOT a PC, stay away from calloc, malloc and the other locs. Erik
generally agree about use of malloc and calloc. But we must use half our data area for one thing at the start and another for later. I suggested an union, but we have not finialized on that. In the meantime I have found my problem: it was supposed to return NULL, that was part of the test. But the NULL was not comparing well vs the standard NULL. So I put in an xdata attribute and all works now. Thank you for your help, Sean
See this thread for a similar problem with pointer comparions and NULL: http://www.keil.com/forum/docs/thread3443.asp
But we must use half our data area for one thing at the start and another for later. I suggested an union, but we have not finialized on that. Why even do that. If the variables are local to two different routines, they will only take one space. Erik
