I'm using quite old version of Keil, 3.20. With following simple code, I get unexpected results. I believe there is some kind of code problem:
xdata char msg1[]="abc"; xdata char msg2[]="def"; void main() { init_8255(); init_lcd(); lcd_open_backlight(); lcd_cursor_on(); // here, i suppose to write "abc" to the first row lcd_print(10, 0, msg1); // here, i suppose to write "def" to the second row lcd_print(10, 1, msg2); strcpy(msg1, "ghi"); strcpy(msg2, "ijk"); // here, i suppose to write "ghi" to the 3rd row lcd_print(10, 2, msg1); // here, i suppose to write "ijk" to the 4th row lcd_print(10, 3, msg2); while (1); }
"abc" "def" "ghi" "ijk"
[empty] "ijk" [empty] "ijk"
#pragma CODE DEBUG SYMBOLS LARGE ROM(LARGE) NOLISTINCLUDE
Besides lcd_print() declaration is as follows:
void lcd_print(unsigned char x, unsigned char y, unsigned char *msg);
Maybe u should test if you get the one line of the LCD working and if you succeed then write a function so you are always calling the lcd_print function once. But your C code looks correct in theory what you have written should work
thanks for the suggession. The problem was the chip. When I use Atmel 89C55WD, I cannot use MOVC succesfully. You know this command is used during initialization. But everthing is OK when 8952 is used with the same board. Any clue?
