Hi, I need to know how to use the WDT in the P89LPC932. I have selected its internal oscillator as the clock source. However, I do not know if it would consume more power than selecting the PCLK as its clock source. Also, how can I find out if the WDT is working fine. Do I need an infinite loop on this function? When do I call it? I have select WDTE = 1; and WDSE = 0; in the UCFG1 register. Sorry for so many questions, but I am still a beginner on this. Thank you void Watch_Dog (void) { EA = 0; WDCON = 0x05; //start WDT, and select WD oscillator WDL = 0xFF; WFEED1 = 0x0A5; //feed sequence WFEED2 = 0x05A; EA = 1; }
for debugging purposes, I recommend that you make a macro e.g. KICK_THE_PUPPY so that you can enable the watchdog for non-debug and disable it for debug in one place (the first 'kick' enables the wd forever). A simple way to test the WD functioning during development is just to start kicking it and it must then time out. Erik
Erik, do you know where can I find samples of this function. On how to use the WDT. I am working on the "KICK_THE_PUPPY". Thank you
do you know where can I find samples of this function. Not a function, make a macro of the two writes (see datasheet). Erik
Erik, this is what I did. I do not understand what is going on here. cacn you explain. I am sorry, but this is more complicated than I thought. I opened the WDT peripheral, but all I see is numbers running and running. Help. #include <Reg932.h> #include <stdio.h> void init(void); void brkrst_init(void); void Kick_the_Puppy(void); void Main(void) { init(); brkrst_init(); Kick_the_Puppy(); } void init(void) { P1M1 = 0x00; // Quasi-bidirectional P1M2 = 0x00; P2M1 = 0x00; // push pull output P2M2 = 0xFF; P0M1 = 0x00; P0M2 = 0xFF; //Output ES = 1; // enable UART interrupt EA = 1; } void brkrst_init(void) // This function allows ISP entry through the UART break detect { //AUXR1 |= 0x40; // enable reset on break detect, pg. 102 SCON = 0x50; // select the BRG as UART baud rate source, pg. 60 SSTAT = 0x00; //Timer1 BRGR0 = 0x70; // 9600 BAUD at @ 7.373MHz internal RC oscillator BRGR1 = 0x04; BRGCON = 0x03; // enable BRG, pg. 59 } void Kick_the_Puppy(void) { EA = 0; WDCON = 0x05; //start WDT, and select WD oscillator WDL = 0xFF; WFEED1 = 0x0A5; //feed sequence WFEED2 = 0x05A; EA = 1; while(1); }
Only the a5/5a load is required to keep the watchdog alive so the code should be
#define KICK_THE_PUPPY WFEED1 = 0x0A5; WFEED2 = 0x05A; void Initialize_the_Puppy(void) { EA = 0; WDCON = 0x05; //start WDT, and select WD oscillator WDL = 0xFF; KICK_THE_PUPPY EA = 1; while(1); // for test }
I have no Idea how to find out if it does reset? uhmm...what about an LED lighting after a reset? if this is a good idea, where in the code should I place that instruction...sorry, but I have no idea, but I want to learn this please. Thank you
there is/are a/some bit(s) for "reset cause" read up on therm and you will know how Erik
Are you talking about the Reset Pin Enable (RPE) bit or the R_EX (external reset flag)? Thank you
I am willing to help, but do not have the time to read the datasheet for you Erik
Erik, I had to go way from this question, because as you have seen I have to take care of other parts of my program like the external interrupt. To see if the WDT resets (i guess (meaning it is working fine)) could I cause a software reset? what about if it does not work fine...how do I do that. There is register called AUXR1 which has a bit for sotfware reset. This will be a good way to know if the WDT is reseting! or do you have a better idea. Thank you!
There is register called AUXR1 which has a bit for sotfware reset The bit is a bit more intricate than that. You must toggle it after a cold reset to get any use out of it. Erik PS in 'standard 51 language' AUXR1 is not not a register, it is a SFR.
I will toggle the SFR AUXR1. But do you think it will be a good exercise...? Let me just make sure...if the WDT resets (works fine) then a software reset should happens by if I set up AUXR1 correctly...right? Then toggle that pin. And this should repit. Right? Thanks
then a software reset should happens by if I set up AUXR1 correctly No, the bit - not "pin" - indicates that a sw reset took place, ir does not make it happen. If you just want to test the watchdog insert a while(); temporarily. Erik
OK, Erik I will do this today and let you know thank you. I still have not resolved my problem with the external interrupt and Power Down, but that will be a different question at a different time.
Erik below is the program I am using to test the WDT. I run it by using only the simulator and it worked fine (I think). This is the sample program "blinky" where port 2 shifts from right to left and left to right. The way I have it here is as follows: as soon as it finishes shifting from right to left, it initializes the WDT and after an overflow, occurs it resets the program. I am still a bit confused. What about in my real application when should I called or initialized the WDT. For what I understand the WDT should always overflow. If it does not (underflowing) then it means a software error while executing occured. therefore, the WDT will cause an system reset. Right? How can I keep a count of WDT underflowing... is there an interrupt for it, or just when it is used as a timer. If so what else should be included there. I have never worked with WDT before so this is new to me. Thanks for your help. #include <Reg932.h> #include <stdio.h> #include <String.h> UCFG1 = 0x88; void init(void); void brkrst_init(void); void Initialize_the_Puppy(void); #define KICK_THE_PUPPY WFEED1 = 0x0A5; WFEED2 = 0x05A; void delay (unsigned int cnt) { while (--cnt); } void Main(void) { brkrst_init(); { unsigned char i; P2M1 = 0; for(;;) { for (i = 0x01; i; i <<= 1) { P2 = i; // simulate running lights delay (50000); } Initialize_the_Puppy(); for (i = 0x80; i; i >>= 1) { P2 = i; delay (50000); } } } } void brkrst_init(void) // This function allows ISP entry through the UART break detect { //AUXR1 |= 0x40; // enable reset on break detect, pg. 102 SCON = 0x50; // select the BRG as UART baud rate source, pg. 60 SSTAT = 0x00; //Timer1 BRGR0 = 0x70; // 9600 BAUD at @ 7.373MHz internal RC oscillator BRGR1 = 0x04; BRGCON = 0x03; // enable BRG, pg. 59 } void Initialize_the_Puppy(void) { EA = 0; WDCON = 0x05; //start WDT, and select WD oscillator WDL = 0xFF; KICK_THE_PUPPY EA = 1; AUXR1 = 0x08; AUXR1 ^= ~0x08; while(1); // for test }
