Compatibility between the C166-Compiler versions ( 3.xx <=> 4.xx )
I have a little question about the compatibility between the C166-Compiler versions :
* 3.05 (uVision 1.24) and
* 4.27 (uVision 2.38) - the actually version
=> I have a SW-Product which contain 2 SW-Projects ('A' and 'B')
'A' communicate with 'B' through a SW-API :
* Global variables
* Pointer to functions (with different parameters)
Both SW-Projects ('A' and 'B') have been compiled with the old Compiler-Version.
{ I can download the both SW-Projects separately }
? Can I use the new C166-Compiler version and re-compile only one of the SW-Project ( 'A' or 'B' )
? The generated code (Function calls [ the used registers ] ) is compatible ?
A lot of thanks in advance,
Steffen
