Good day.
I´d like to ask you, how can I edit code competition in Keil uVision 5? I need instead of character "_" character "->". Is it possible?
Here is, what I need: https://imgup.cz/image/LbMx
Thanks.
You mean, completion ?
Have you checked the manual:
http://www.keil.com/support/man/docs/uv4/uv4_ui_using_editor.htm
Yes, of course.
But I can´t to find, how to change it. Please, could you help me?
As confirmed by Keil's developer:
Please note that the idea of code completion is not to replace code sequences:
http://www.keil.com/support/man/docs/uv4/uv4_ui_codecomp.htm
Now that the forum has moved to the new ARM "Community", we can see Pont Aq's screenshot in context (without having to risk an external link):
rkopsch said:the idea of code completion is not to replace code sequences
Indeed.
That would be what's sometimes referred to as "refactoring".
I don't believe that uVision has any support from that - beyond the basic text search & replace ?
One of the thing that annoys me the most is it insisting on making for( into FORMAT_BCD( it honestly has to be the dumbest auto-complete engine ever. That's not even a macro/function in my code, but something it is pulling out of the library includes some where.
How can FORMAT_BCD be MORE prevalent in the entire code base than the keyword for, to the point it is more probable I'm typing that, while using lower case, and wanting to insert that into the stream as I'm trying to type?
