I want to change the kernel's Timer0 to Timer2 when using RTX51 Tiny. Now I have modified something in file Conf_tny.A51:
Code-1
;CSEG AT 0x0B ;Timer0 interrupt adress (oringal code) CSEG AT 0x2B ;Timer2 interrupt adress JMP TIMERINT
Code-2
; Update 8051 Interrupt Timer CLR TF2 ï¼›Clear Timer2 TF ;CLR TR0 ï¼›(oringal code) ;MOV A,TL0 ;ADD A,#LOW (?RTX_CLOCK + 7) ;MOV TL0,A ;MOV A,TH0 ;ADDC A,#HIGH (?RTX_CLOCK + 7) ;MOV TH0,A ;SETB TR0
Code-3
;ORL TMOD,#01H ; Timer 0 Mode 1 (oringal code) ;MOV TL0,#LOW (?RTX_CLOCK) ;MOV TH0,#HIGH (?RTX_CLOCK) ;SETB TR0 ;SETB EA ;SETB ET0 CLR TR2 CLR TF2 MOV T2CON,#00H ; Timer 2 Mode 1 MOV T2MOD,#80H MOV TMCON,#04H MOV TL2,#LOW (?RTX_CLOCK) MOV TH2,#HIGH (?RTX_CLOCK) MOV RCAP2L,#LOW (?RTX_CLOCK + 7) MOV RCAP2H,#HIGH (?RTX_CLOCK + 7) SETB TR2 SETB EA SETB ET2
After debugging simulation, I found an exception in os_wait(). What else do I need to modify?
