I was trying to import a project from mbed online compiler to uvision5. So, I followed this tutorial: http://www.keil.com/appnotes/files/apnt_207_v2.0.pdf But when I executed the command: mbed export -i uvision5 -m disco_l072cz_lrwan1 it returned the error "No module named jsonschema"
You can see the execution here:
[mbed] Working path "C:\Users\emman\GoogleDrive\Keil\DISCO-L072CZ-LRWAN1_blink_leds" (program) Traceback (most recent call last): File "C:\Users\emman\GoogleDrive\Keil\DISCO-L072CZ-LRWAN1_blink_leds\.temp\tools\project.py", line 19, in <module> from tools.export import ( File "C:\Users\emman\GoogleDrive\Keil\DISCO-L072CZ-LRWAN1_blink_leds\.temp\tools\export\__init__.py", line 29, in <module> from ..config import ALLOWED_FEATURES File "C:\Users\emman\GoogleDrive\Keil\DISCO-L072CZ-LRWAN1_blink_leds\.temp\tools\config\__init__.py", line 31, in <module> from jsonschema import Draft4Validator, RefResolver ImportError: No module named jsonschema [mbed] ERROR: "C:\Python27\python.exe" returned error. Code: 1 Path: "C:\Users\emman\GoogleDrive\Keil\DISCO-L072CZ-LRWAN1_blink_leds" Command: "C:\Python27\python.exe -u C:\Users\emman\GoogleDrive\Keil\DISCO-L072CZ-LRWAN1_blink_leds\.temp\tools\project.py -i uvision5 -m disco_l072cz_lrwan1 --source ." Tip: You could retry the last command with "-v" flag for verbose output ---
Anyone have an idea please? Emmanuel
I finally discovered the reason of this error. It is necessary to install a package jsonschema. In a terminal: pip install jsonschema
Then I had another error: File "c:\Users\emman\GoogleDrive\Keil\DISCO-L072CZ-LRWAN1_blink_leds\.temp\tools\project.py", line 145, in export notify.info("Using targets from %s" % targets_json) AttributeError: 'NoneType' object has no attribute 'info' [mbed] ERROR: "C:\Python27\python.exe" returned error. Code: 1 Path: "c:\Users\emman\GoogleDrive\Keil\DISCO-L072CZ-LRWAN1_blink_leds" Command: "C:\Python27\python.exe -u c:\Users\emman\GoogleDrive\Keil\DISCO-L072CZ-LRWAN1_blink_leds\.temp\tools\project.py -i uvision5 -m disco_l072cz_lrwan1 --source ." Tip: You could retry the last command with "-v" flag for verbose output ---
To resolve it, I only comented line 145 of project.py file. After that, all worked fine.
Emmanuel
