[8051] Use keil-C simulator and debug problem?
Dear all, my code is listed as below, my 8051 is Cast R8051XC2
sbit LED_FPGA_LED7=P1^0; sbit LED_FPGA_LED6=P1^1; sbit LED_FPGA_LED5=P1^2; sbit LED_FPGA_LED4=P1^3;
sbit LED_FPGA_LED3=P0^0; sbit LED_FPGA_LED2=P0^1; sbit LED_FPGA_LED1=P0^2; sbit LED_FPGA_LED0=P0^3;
void Timer0_IntHandler(void) interrupt 1 { static U8 u8Count0=0; U16 u16tmp=0; bit bLedTemp0_BDATA=0; U8 u8LedTmp0_IDATA=0; //DATA:0x0~0x7F static U8 u8LedTmp0_XDATA=0;
EAL = 0; ET0 = 0;
TH0=0x01; TL0=0x55;
bLedTemp0_BDATA=LED_FPGA_LED7; u8LedTmp0_IDATA=LED_FPGA_LED7; u8LedTmp0_XDATA=LED_FPGA_LED7;
bLedTemp0_BDATA=~bLedTemp0_BDATA; u8LedTmp0_IDATA=~u8LedTmp0_IDATA; u8LedTmp0_XDATA=~u8LedTmp0_XDATA;
LED_FPGA_LED7=~LED_FPGA_LED7; if(0==(u8Count0%5)){ LED_FPGA_LED6=~LED_FPGA_LED6; }
u8Count0++; ET0 = 1; EAL = 1; }
void Timer1_IntHandler(void) interrupt 3 { static U8 u8Count1=0; bit bLedTemp1=0;
EAL=0; ET1=0;
if(0==(u8Count1%10)){ bLedTemp1=LED_FPGA_LED5; LED_FPGA_LED5=(~bLedTemp1); //LED_FPGA_LED5=~LED_FPGA_LED5; } if(0==(u8Count1%15)){ bLedTemp1=LED_FPGA_LED4; LED_FPGA_LED4=(~bLedTemp1); //LED_FPGA_LED4=~LED_FPGA_LED4; u8StnCount++; }
u8Count1++; ET1=1; EAL=1; }
void Timer2_ISR (void) interrupt 5 { static U8 u8Count2=0; EAL=0; ET2=0; #if 0 if(!(u8Count2%50)){ static U8 u8ShowCount=0; Drv_WriteByteToStn(1,0,0x41+u8ShowCount); u8ShowCount++; }
u8Count2++; #endif TF2=0; //clear overflow flag ET2=1; EAL=1; }
void EX3_ISR (void) interrupt 10 { bit bEx3Temp=0; EAL=0; EX3=0;
bEx3Temp=LED_FPGA_LED3; LED_FPGA_LED3=(~bEx3Temp); //LED_FPGA_LED3=~LED_FPGA_LED3;
EX3=1; EAL=1; }
void EX4_ISR (void) interrupt 11 { bit bEx4Temp=0; EAL=0; EX4=0;
bEx4Temp=LED_FPGA_LED2; LED_FPGA_LED2=~bEx4Temp; //LED_FPGA_LED2=~LED_FPGA_LED2;
EX4=1; EAL=1; }
void EX5_ISR (void) interrupt 12 { bit bEx5Temp=0; EAL=0; EX5=0; bEx5Temp=LED_FPGA_LED1; LED_FPGA_LED1=(~bEx5Temp); //LED_FPGA_LED1=~LED_FPGA_LED1;
EX5=1; EAL=1; }
void EX6_ISR (void) interrupt 13 { bit bEx6Temp=0; EAL=0; EX6=0; bEx6Temp=LED_FPGA_LED0; LED_FPGA_LED0=(~bEx6Temp); //LED_FPGA_LED0=~LED_FPGA_LED0;
EX6=1; EAL=1; }
I use simulator in Keil-C Q1: The initial value of LEDs all are "1". The interrupt occured sequence is EX3 -> EX4 --> Timer0 ->EX5 ->Timer1 -> EX6 ->Timer0 ->Timer1 my main function is always runnging in while(1){ } loop and doing nothing.
When I use debug mode to trace the changing of LEDs. After running Timer1-ISR, the all valus of LEDs change correctly. But after Timer1-ISR and before EX6-ISR I don't know why the LED_FPGA_LED4 changes from 0 to 1.
LED_FPGA_LED7=1 --->0--------->1 LED_FPGA_LED6=1 --->0--------->0 LED_FPGA_LED5=1 ----->0 LED_FPGA_LED4=1 ----->0->1------->0 (enter Timer1-ISR again, it becomes 0, but who changes it?) |->(the problem point, I don't know who changes it.)
LED_FPGA_LED3=1 ->0 LED_FPGA_LED2=1 -->0 LED_FPGA_LED1=1 ---->0 LED_FPGA_LED0=1 ---------->0
Q2: In the Timer0-ISR, I declares several variables, one of them is u8LedTmp0_IDATA. I found it will be located at DATA:0x7 in running time. But it seems I could not change it's value after u8LedTmp0_IDATA=LED_FPGA_LED7. It always keeps in the same value. After I check the 8051 specification. it says the 0x0~0x1F are work registers for R0~R7. Is it the root casue? How could I set the keil-C not use 0x0~0x1F in running time?
Thanks a lot.
  • Please follow the instructions for posting source code.
    Look at this picture to help you: www.danlhenry.com/.../keil_code.png
  • Sorry, new post for code alignment
    Dear all,
    EAL = 0; ET0 = 0;
    TH0=0x01; TL0=0x55;
    EAL=0; ET1=0;
    u8Count2++;
    EX3=1; EAL=1;
    EX4=1; EAL=1;
    EX5=1; EAL=1;
    EX6=1; EAL=1;
    Q1:
    LED_FPGA_LED4=1 ----->0->1(the problem point, I don't know who changes it.)------->0 (enter Timer1-ISR again, it becomes 0, but who changes it?)
    LED_FPGA_LED3=1 ->0
    Q2:
    Is it the root casue? How could I set the keil-C and let the 8051 does not use DATA:0x0~0x1F in running time?
    Thanks a lot.
  • You didn't follow the instructions, did you ?
    Look at that picture again: www.danlhenry.com/.../keil_code.png
    it's really not hard, and it would be obvious from the preview when it's worked.
  • Dear all, Sorry, I just see your reply now.
      U16 u16tmp=0;
      EAL = 0; ET0 = 0;
      TH0=0x01;
      TL0=0x55;
      if(0==(u8Count0%5))
      u8Count0++;
      ET0 = 1;
      EAL = 1;
      bit bLedTemp1=0;
      EAL=0;
      ET1=0;
      u8Count1++;
      ET1=1;
      EAL=1;
      EAL=0;
      ET2=0;
      bit bEx3Temp=0;
      EAL=0;
      EX3=0;
      EX3=1; EAL=1;
      bit bEx4Temp=0;
      EAL=0;
      EX4=0;
      EX4=1; EAL=1;
      bit bEx5Temp=0;
      EAL=0;
      EX5=0;
      EX5=1;
      EAL=1;
      bit bEx6Temp=0;
      EAL=0;
      EX6=0;
      EX6=1;
      EAL=1;
    LED_FPGA_LED3=1 ->0
    Q2: In the Timer0-ISR, I declares several variables, one of them is u8LedTmp0_IDATA. I found it will be located at DATA:0x7 in running time. But it seems I could not change it's value after u8LedTmp0_IDATA=LED_FPGA_LED7. It always keeps in the same value. After I check the 8051 specification. it says the 0x0~0x1F are work registers for R0~R7. Is it the root casue? How could I set the keil-C and let the 8051 does not use DATA:0x0~0x1F in running time?
    Thanks a lot.
  •   U8 u8LedTmp0_IDATA=0; //DATA:0x0~0x7F static U8 u8LedTmp0_XDATA=0;
    As a temporary variable will always be set to 0 at ISR entry
    set to a value never used
    zeroing it out
    what are you trying to do? nothing??
    I dislike you include IDATA in a label of soething you have no idea where it goes
  •   bLedTemp0_BDATA=LED_FPGA_LED7;
    1. Yes, it does nothing. I just monitor where the variables are placed.
    2. About IDATA label , Sorry I forgot to modify it's name. It should be DATA, because this variable(u8LedTmp0_IDATA) will be placed in DATA area.
  • Which is exactly why you should not have it in the name at all - as Joe said!
  • Please ignore my Q2. I just know the root cause. Thank you.
