Hello i am trying to build a simple DMA program to read ADC values and its working but not completely
the problem is here: at first this code is working 1.
u[0]=((float)ADC_Data[0])*3; sprintf(str,"%.2fv ",u[0]); LCD_SetPos(0,0); LCD_String(str);
when changed to : or even divide by 1 its not working any more and the LCD is too slow
u[0]=((float)ADC_Data[0])*3/4096; sprintf(str,"%.2fv ",u[0]); LCD_SetPos(0,0); LCD_String(str);
2. the debugger is updating the correct u[0] in this code without a problem:
but in this code not !!! why even when i put the 3 lines to comments its must not affect the u[0] value
u[0]=((float)ADC_Data[0])*3; // sprintf(str,"%.2fv ",u[0]); // LCD_SetPos(0,0); // LCD_String(str);
please please i spend hours ... hours without any success please help why the division is not working and the bug in updating u[0] value i tryied to use volatile variable double or others but always when i use division the code runs very slow
the full code is generated with Cubemx.
www.mediafire.com/.../file
volatile uint16_t ADC_Data[3]; // Changed by DMA, not normal code flow, must be volatile double d[3]; // sprintf works on doubles char str[32]; // plenty of space .. d[0]=(double)ADC_Data[0]) * (3.0 / 4096.0); // use floating point sprintf(str,"%.2lfv ",d[0]); LCD_SetPos(0,0); LCD_String(str);
