rtos L6200E Symbol multiply defined rtx
I'm working on a little service firmware using RTX.
At all I don't wanted to write hole code in one File so I split my code in logical units.
So far so good.
Now I want send Data from one to another thread.
I've read in "osObjects.h" file that I can define global RTOS objects there.
Maybe this is a beginner fault but I'm the opinion to use this "osObjects.h" in every file
I use RTOS objects.
By building the project I get several Error: L6200E: Symbol "text" multiply defined...
I define a memory pool this way:
File objects.h:
typedef struct { uint16 Temperature; uint8 MotorStatus; uint16 ack_hex_Motor;
} mp_writeData_t;
osPoolId mpid_writeData;
osPoolDef(mp_writeData, 1,mp_writeData_t);
osMessageQId qid_writeData;
osMessageQDef(q_writeData, 1, &mp_writeData_t);
So I've leave no stone unturned and tried with declare as extern and static,
with static I reduced the errors to a minimum but there also errors.
The threads declared in objects.h File work fine ...
Maybe someone as an idea or help on me.
regards
0
