Hello, In our production process there are some C8051F060-based devices which encounter ADC none-linearity issues. When reviewing the Calibration section at the user manual's ADC chapter it isn't totally clear which steps are needed to be done.
in the user's manual, page 66 appears: If linearity calibrations are desired, they can be initiated by setting the ADCnLCAL bit to ‘1’. When the calibration is finished, the ADCnLCAL bit will be set to ‘0’ by the hardware. Is that all that is needed to be done? Is there no need to set the ADC0CPT and ADC0CCF for linearity calibration purpose, but only for the gain and offset calibration?
Will this piece of code be enough? -
// Switch to ADC0 Page SFRPAGE = ADC0_PAGE; // ADC0 Disabled, Timer3 start-of-conversion // track 16 SAR clocks before data conversion // upon Timer3 OV. DMA will enable ADC as needed ADC0CN = 0x44; // turn on bias generator and internal reference. REF0CN = 0x03; // Wait for Vref to settle (large cap used on target board) for(i = 0; i < 10000 ;i++); // Single-ended mode AMX0SL = 0x00; // Select SAR clock frequency =~ 25MHz ADC0CF = 0x00; ADC0LCAL = 1; // Initiate linearity calibration while(ADC0LCAL != 1) // restore SFRPAGE SFRPAGE = old_SFRPAGE;
Thanks, Amitai
Keil didn't write that manual, and Keil don't make that chip - this has nothing to do with Keil.
For clarification of a manufacturer's documentation and product-specific features & procedures, you need to contact the manufacturer - in this case, SiLabs
See 'Community & Support' at https://www.silabs.com/
