I am currently in the process of porting my C program from SDCC to Keil because of several reasons. (bugs, lack of support, limitations)
What I would like to know is how some of the syntax changes look like.
So far I have figured out that __xdata becomes xdata and I cannot enter binary values.
I am having a lot of issues with the keil compiler at the moment so I will keep it short.
The special functions registers look like: __sfr __at 0xE0 ACC ;
I believe this must look like: sfr ACC = 0xE0; correct?
And is the same true for sbit?
__sbit __at 0x88 IT0 ; --> sbit IT0 = 0x88; ???
Than I'd like to know how the interrupt syntax looks like. It currently looks like this: void ISR_ex0(void) __interrupt 0
A huge problem we're having is that this interrupt 0 in SDCC is linked to a certain stack address (0x03). In SDCC I have no control over the link between address and interrupt numbers. This is baked in the compiler. I am programming an emulated 80c51 chip. The 'chip' is emulated on an FPGA and it comes with a lot of extras such as extra timers, 4 more I/O ports and 8 I/O interrupts rather than two. Now I can only use 2/8 interrupts.
look in the documentation
that is not SDCC that is hardware
As already noted, porting from one compiler to another will always require a thorough study of the documentation for both compilers - in particular, the implementation-defined standard aspects and any non-standard extensions.
The usual approach is to "wrap" the dependencies in conditional compilation; eg,
#if defined SDCC #define XDATA __xdata #elif deinfed KEIL #define XDATA xdata #else #error "Unknown compiler" #endif
You will have to look up the actual symbols to identify the two compilers.
I would suggest that you maintain both versions - so that you can always go back to the SDCC version to check that your Keil version is still working as required.
If you're lucky, you might find that someone has already done this ...
most (all?) SiLabs sample code can run either SDCC or Keil
you are wrong because it isn't just the hardware, it never is "just the hardware".
When one compiles a program in SDCC , he has to add a parameter which tells SDCC for what hardware SDCC is compiling. Than SDCC links the interrupts to the hardware addresses. But it is SDCC which does this for you. And I need to be able to it myself because of our FPGA chips. And this shouldn't be impossible.
Please read the manual: http://www.keil.com/support/man/docs/c51/c51_le_interruptfuncs.htm
http://www.keil.com/support/man_c51.htm
http://www.keil.com/appnotes/list/c51.htm
http://www.keil.com/download/list/c51.htm
Tnx. The manuals are quite usefull. With SDCC I never used a manual because I didn't had to. From the library files as well as an example program I could get what I needed with ease. I will take a look in Keil's as well.
I only don't onderstand the "using" keywoard yet, I never did. I've read the manual about it but I am not getting the purpose of the register banks and in partically what "using" does when used in combination with the interrupts. I only know that if you call a function from within a function, they should be in the same register bank to prevent strange behaviour
For my serial interrupt I use "using 2" because it was there in an example program. But I don't understand why or what.
Well, if SDCC doesn't have the feature then, presumably, none of your existing code uses it - so you don't need to worry about it at this point!
Start a separate, specific thread once you've got the basic port done.
When one compiles a program in SDCC , he has to add a parameter which tells SDCC for what hardware SDCC is compiling. Than SDCC links the interrupts to the hardware addresses. But it is SDCC which does this for you. And I need to be able to it myself because of our FPGA chips. And this shouldn't be impossible.</i?
it is the interrupt addrsses are fixed in hardware.
www.danlhenry.com/.../80C51_FAM_ARCH_1.pdf www.danlhenry.com/.../80C51_FAM_HARDWARE_1.pdf www.danlhenry.com/.../80C51_FAM_PROG_GUIDE_1.pdf
the above will also educate you re register banks
There is a good tutorial on the four distinct register banks of an 8051 (in the "Register Banks" section)
www.8052.com/tutmemor.phtml
Unless you say otherwise, we use register bank 0, but you could reserve another of the register banks for a function, so you can always have its registers ready to go.
The compiler can even take advantage of this when you turn on "Global register coloring"
http://www.keil.com/support/man/docs/c51/c51_ap_opt_grc.htm
See the other function declaration extensions at:
http://www.keil.com/support/man/docs/c51/c51_le_funcdecls.htm
the most useful use of register banking is ISRs
