How to address the ports of the Teridian 71M6541FT processor, when developing software in the µVision program on C?
Ports list: SEGDIO0 – SEGDIO14 SEGDIO19 – SEGDIO27 SEGDIO36 – SEGDIO39 SEGDIO44 SEGDIO45 SEGDIO51 COM0 – COM3 SEG46 SEG47 PB VLCD VREF IAP IAN V3P3A VA TEST GNDA XOUT XIN VBAT_RTC VBAT V3P3SYS IBP IBN GNDD V3P3D VDD ICE_E SEG48 – SEG50 RX TX
yea but name doesnt work for SEGDIO45 or the oters.
why does the mku have the pins not known to uvision?
what library do i need
why does the mku have the pins not known to uvision? Keil does not 'know' pins, Ke, as a service, provide some libraries. 'advanced' chips kave 'pins' not in the basic '51
what library do i need check maxim there might be one there, if not the datasheet should give enough information for you to make your own
http://www.keil.com/support/man/docs/c51/c51_le_sfrs.htm
http://www.keil.com/dd/chips/tsc/8051.htm
Unfortunately, I'm not familiar with the Teridian 71M6541FT processor. Ports are usually controlled and configured with SFRs or sometimes with memory mapped registers in the XDATA space. Since I don't have any information about this device, I cannot help you with a concrete header file. I only found a datasheet for a 71M6543 device which should be similar. On page 34 and table 14 you can see how the pins SEGDIO0 – SEGDIO15 are mapped to the P0, P1, P2 and P3 SFRs and their addresses. You should have a similar table for your device and its pins as well. The previous link already shows you how to define SFRs. You can also take a similar header file and adapt it to your device.
