Hi All,
Please have a look at below code from makefile.
$(OUTPUT_FILE_PATH): $(OBJS) @echo Building target: $@ @echo Invoking: ARM/GNU Linker : 4.8.4 $(QUOTE)$(COMPILER_PATH)\armlink.exe$(QUOTE) --cpu Cortex-M0+ "Mcal\lib\MCAL.lib" -o$(OUTPUT_FILE_PATH) $(OBJS) --library_type=microlib --strict --scatter "linker_scripts\samd21\keil\SAMD21.sct" --summary_stderr --info summarysizes --map --xref --callgraph --symbols --info sizes --info totals --info unused --info veneers --list "listings\mapfile.map" @echo Finished building target: $@
I have created Cortex M0+ specific driver library. I am able to link this library to my ECAL code. But i ahve one more core specific library which i am trying to link. "CoreM0+.lib"
I have modified the above makefile as below $(OUTPUT_FILE_PATH): $(OBJS) @echo Building target: $@ @echo Invoking: ARM/GNU Linker : 4.8.4 $(QUOTE)$(COMPILER_PATH)\armlink.exe$(QUOTE) --cpu Cortex-M0+ "Core\CoreM0+.lib","Mcal\lib\MCAL.lib" -o$(OUTPUT_FILE_PATH) $(OBJS) --library_type=microlib --strict --scatter "linker_scripts\samd21\keil\SAMD21.sct" --summary_stderr --info summarysizes --map --xref --callgraph --symbols --info sizes --info totals --info unused --info veneers --list "listings\mapfile.map" @echo Finished building target: $@ My understanding as per input-file-list keyword from compiler reference is to add multiple library files by seperating them with comma. Please let me know any other workaround or alternative.
Thanks in Advance, Parag.
