Hello there
I'm trying to compile and link position independent code using the --apcs=/ropi compile option (C/C++: Read-Only Position Independent). Since I'm using --scatter I can't make use of the linker option "Make RO Sections Position Independent. Instead I mark the RO execution region in my scatter file with the PI option (as mentioned in this post: www.keil.com/.../).
It compiles just fine, but I get the L6248E Linker Error mainly because of the startup file. I understand that the assembler can't generate position independent code. I tried to write the startup code in C so that the compiler takes care of the position independency, unfortunately without success.
It seems like the DCD directive is causing the linker error. Does anyone have a suggestion or solution to my problem? Any help is appreciated.
Im using a STM32F100 Controller with Keil uVision 4.5 Standard Version (Armcc, ArmLink V4.1.0.894)
Here is my scatter file:
LR_IROM1 0x08000000 0x00010000 { ; load region size_region ER_IROM1 0x08000000 PI 0x00010000 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) } RW_IRAM1 0x20000000 0x00002000 { ; RW data .ANY (+RW +ZI) } }
and my Startup File (vector table):
; Vector Table Mapped to Address 0 at Reset AREA RESET, DATA, READONLY EXPORT __Vectors EXPORT __Vectors_End EXPORT __Vectors_Size __Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler DCD NMI_Handler ; NMI Handler DCD HardFault_Handler ; Hard Fault Handler DCD MemManage_Handler ; MPU Fault Handler DCD BusFault_Handler ; Bus Fault Handler DCD UsageFault_Handler ; Usage Fault Handler DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD SVC_Handler ; SVCall Handler DCD DebugMon_Handler ; Debug Monitor Handler DCD 0 ; Reserved DCD PendSV_Handler ; PendSV Handler DCD SysTick_Handler ; SysTick Handler ... __Vectors_End __Vectors_Size EQU __Vectors_End - __Vectors AREA |.text|, CODE, READONLY ; Reset handler Reset_Handler PROC EXPORT Reset_Handler [WEAK] IMPORT __main IMPORT SystemInit LDR R0, =SystemInit BLX R0 LDR R0, =__main BX R0 ENDP ; Dummy Exception Handlers (infinite loops which can be modified) NMI_Handler PROC EXPORT NMI_Handler [WEAK] B . ENDP HardFault_Handler\ PROC EXPORT HardFault_Handler [WEAK] B . ENDP ...
Thank you
Roland
