STM32F103 change startup file from startup_stm32f10x_md.s TO startup_stm32f10x_cl.s
I'm using STM32103C8 board, during creating program in manage run time environment I select CMSIS and startup under DEVICE then it creates "startup_stm32f10x_md.s" startup file. Can I change it to startup_stm32f10x_cl.s .
Basically I've STM32F105 configured code and I want it run on STM32F103C8. What changes I have to do?
In file stm32f10x.h and this file is read only
#if !defined (STM32F10X_LD) && !defined (STM32F10X_LD_VL) && !defined (STM32F10X_MD) && !defined (STM32F10X_MD_VL) && !defined (STM32F10X_HD) && !defined (STM32F10X_HD_VL) && !defined (STM32F10X_XL) && !defined (STM32F10X_CL) /* #define STM32F10X_LD */ /*!< STM32F10X_LD: STM32 Low density devices */ /* #define STM32F10X_LD_VL */ /*!< STM32F10X_LD_VL: STM32 Low density Value Line devices */ /* #define STM32F10X_MD */ /*!< STM32F10X_MD: STM32 Medium density devices */ /* #define STM32F10X_MD_VL */ /*!< STM32F10X_MD_VL: STM32 Medium density Value Line devices */ /* #define STM32F10X_HD */ /*!< STM32F10X_HD: STM32 High density devices */ /* #define STM32F10X_HD_VL */ /*!< STM32F10X_HD_VL: STM32 High density value line devices */ /* #define STM32F10X_XL */ /*!< STM32F10X_XL: STM32 XL-density devices */ /* #define STM32F10X_CL */ /*!< STM32F10X_CL: STM32 Connectivity line devices */
#endif
Note:
- Connectivity line devices are STM32F105xx and STM32F107xx microcontrollers.
- Medium-density devices are STM32F101xx, STM32F102xx and STM32F103xx microcontrollers where the Flash memory density ranges between 64 and 128 Kbytes.
0
