Reverse working of Switch
When I am executing this code, the LED is ON by default whereas it should only be ON when switch is pressed. And when I press the switch, it turns off. Can anyone please explain me, what I am doing wrong with my code.
</ #include <lpc17xx.h>
#define SwitchPinNumber 11
#define LedPinNumber 6
void main()
uint32_t switchStatus;
SystemInit();
LPC_PINCON->PINSEL4 = 0x000000; //Configure the Pins for GPIO;
/* Configure the LED pin as output and SwitchPin as input */
LPC_GPIO2->FIODIR = ((1<<LedPinNumber) | (0<<SwitchPinNumber));
while(1)
/* Turn On all the leds and wait for one second */
switchStatus = (LPC_GPIO2->FIOPIN>>SwitchPinNumber) & 0x01 ; //Read switch status
if(switchStatus == 1)
LPC_GPIO2->FIOPIN = (1<<LedPinNumber);
else
LPC_GPIO2->FIOPIN = (0<<LedPinNumber);
  • Two two things spring to mind.
    How is the switch connected? Does the port pin have a pull up and a switch that takes the line to ground or does the port pin have a pull down and a switch that takes the line to +VE ?
    How are the LEDs connected? One end tied to ground and the other to the port pin that goes high to turn it on or one end tied to +VE and the other to a port pin that goes low to turn it on?
    Consider these and consider what your code is doing.
  • "Switch Pin is in Pull Up state". The LED's are connected to Micro controller pin and GND. When the switch is pressed, it should drive the LED Pin high, I however rectified this program, now I am facing trouble while employing switch in another program.
    < uint32_t switchStatus;
    LPC_PINCON->PINSEL3 = 0x000000;
    LPC_GPIO1->FIODIR = (0<<SwitchPinNumber));
    SystemInit();
    timer0_init();
    switchStatus = (LPC_GPIO1->FIOPIN>>SwitchPinNumber) & 0x01 ;
    if(switchStatus ==0 )
    while(1)
    { for(i=0; i<=8; i++) {
    uart_init(Baudrate[i]);
    read();
    if(flag0==1)
    break;
    if (flag0==1)
    Glow_GreenLED();
    else
    Glow_RedLED();
  • No surprise. Look at what your program is trying to do. Not very smart :(
  • Can you please tell me where I am going wrong?
  • Sorry but I'm not here to let people cheat with their first year school projects.
  • Instead of your profound sarcasm, I would have really appreciated your guidance. I was not asking you to write the source code, if that's what you thinking mate!
  • OK.
    Firstly:
    Look at what you've posted. Look at how you've posted it.
    Did you read the information under http://www.keil.com/forum/tips.asp ?
    It's terrible.
    Then:
    Did you read my previous post? did you actually understand it? Your second code snippet (aka mess) indicates that you didn't do at least one of those things
    Then:
    The code snippet is incomplete and has obvious things missing. Example, wtf is flag0? where do you define it? where do you initialise it?
    Then:
    Why are you initialising the UART within a loop like that?
    In summary:
    It's really not very good. My pre-teen daughter recognised some of the faults in what you had posted!
