Cannot delete uvision
i planned to upgrade my MDK uvison 4
each time i try to installing the new versions
the installation app recognizes the previous version
although i do not mark retain the current uvision configuration ,
i see related file to previous version (i.e projects )
i've tried removing uvision 4,and 5 in program and feature in control panel for
several times and still this happens .
how can i totally delete the previous version
i mean even from registry files. ?!
like it is first time to install the app
  • Multiple versions can co-exist, install into a unique directory, delete the trees you don't want.
  • Of course, uninstalling the tools will not uninstall the work that you previously did using those tools - ie, your projects!!
    That is certainly the correct and expected operation!
    There would be a lot of very angry customers if uninstalling the tools deleted all their work!!
    Projects are just normal files - you can just delete them when you no longer require them.
  • i really did not mean deleting project.
    for example when i installed the new uvison 5 , it will open my previous projects while its the first time i run the application .
    i think there must be some registry files that are not being deleted after un-installation of the app .
    anyway this act of app can be ignored as it doesn't effect the job .
    forget this ...
