I try to generate a sfr file for the system viewer to look at the registers of my STM32F469. I already have installed the Keil.STM32F4xx_DFP.2.11.0 Pack & CMSIS 5.0.1 and tried to generate the file out of STM32F46_79x.svd but that doesn't work. I get several errors and the Converter looks for the executable SfrCC2.exe, which I cannot find.
My command: SVDConv.exe ..\CMSIS\SVD\STM32F46_79x.svd --generate=sfr
This is where I got this from: http://www.keil.com/support/man/docs/uv4/uv4_ut_svdconv.htm
From the converter I get an .sfd file.
How can I generate an SFR File? Anyone had the same problem?
Kind regards Andreas
The missing converter SfrCC2.exe is located at C:\Keil_V5\UV4
thank you! That worked!
