we bought the sources of the file system and I think I found a bug in the sources (bug in all releases to 7.3.0) :
When there are no files in the SD card, the file system crashes in function "elink_rewind" of file "fs_fat_elink" because "el" local variable is initialized to 0 and used as pointer further.
Add the code below to fix the bug :
static ELINK *elink_rewind (uint32_t dir, ELINK_CACHE_CB *nc) { ELINK *el; el = nc->Used[nc->Depth].Oldest; if (el == NULL) { return NULL; } if (dir <= el->Info.DirClus) {
