µVision Editor 'Smart HighLighting'
does anyone know wether the uVision editor is able to do 'Smart HighLighting' like notepad++ does?
If one doesn't know: if you select a word in notepad++ all appearences will be highlighted instantly. This is a very helpful feature, because you get an instant overview within the editor (not in a seperate find window), where a specific item (variable or else) appears.
uV editor uses the same core as notepad++, thus it must be possible in principle. And I assume it should be easy to add.
Can anyone from KEIL say, how they are thinking about add this feature? Or is it already availible and I wasn't able to activate it?
Best regards.
Matz.
0
