Before build execution failde
Hi all,
I created one small tool to generate FW_build_info.h file with following content:
#ifndef BUILD_Info
#define BUILD 1
#define BUILD_Date 24.10.2016
#define BUILD_Time 14:11:02
#endif
I wrote this code in C# using VS2015. Program works normally as far as it is executed directly from windows explorer or command prompt, but when I put it to uVision as Before Build command it wont work at all.
In Build Output there is log for it
Before Build - User command #1: FW_Build_Info.exe
but no FW_build_info.h was created.
Thanks for your help.
Regards
Martin
  • Not sure about why your build step failed.
    But shouldn't your file look like:
    #ifndef BUILD_Info
    #define BUILD 1
    #define BUILD_Date "24.10.2016"
    #define BUILD_Time "14:11:02"
    #endif
    Or how did you plan to actually use the BUILD_Date and BUILD_Time symbols, since the final result has to expand into something that is valid C/C++ which most probably then would be a string.
    And if you now or in the future target an international market, you might consider switching the date format to "2016-10-24" - in a number of countries, there will be a huge confusion if your date format has days or months first.
  • Perhaps it is not writing to the directory you think it is. If it was a C program consider writing to a log file with an explicit path, or doing a getch()
