CSEG AT 0x400 karray: DS (8*16)
I reserve memory space in starup.a51 file as follow
CSEG AT KARRAYDATADDR ;0x017c
karray:
DS (8*16)
} And then,when I use asm Compiler directly in a c file as follow
#pragma asm
MOV R1,#HIGH (karray)
MOV R1,#LOW (karray)
#pragma endasm
I receive the following error message:
.\obj\cprm.src(4095): error A14: BAD RELOCATABLE EXPRESSION
I find that the src file(cprm.src) have replace the expression as follow
; MOV R1,#HIGH (karray)
MOV R1,# (karray>>8)
; MOV R1,#LOW (karray)
MOV R1,# (karray)
What is going on and how can I fix it?
  • I find that the src file(cprm.src) have replace the expression as follow
    MOV R1,# (karray)
    HIGH(x) means the upper 8 bits of a 16-bit value. So the address of karray shifted right 8 steps.
    LOW(x) means the lower 8 bits of a 16-bit value.
    So the compiler haven't changed anything - it has just expressed the same thing but in a different way.
    But why assign both the high 8 bits and the low 8 bits to the same 8-bit register?
  • Sorry,I I didn't mean to assign to the same 8-bit register.It is a test case.The correct case should be following.
    #pragma asm
    MOV ER01,#HIGH (karray)
    MOV ER00,# (karray)
    #pragma endasm
    } Return to Error A14.
    Error A14 mean
    *** Error A14 Bad Relocatable Expression
    A relocatable expression was invalid. Valid relocatable expressions may contain only one relocatable symbol which may be a segment symbol, external symbol, or a symbol belonging to a relocatable segment. The assembler cannot perform mathematical operations involving more than one relocatable symbol.
    There are also restrictions for arithmetic operations with symbols as described under Relocatable Expressions.
    Following is from keil help:
    Relocatable expressions are so named because they contain a reference to a relocatable or external symbol. These types of expressions can only be partially calculated by the assembler since the assembler does not know the final location of relocatable segments. The final calculations are performed by the linker.
    A relocatable expression normally contains only a relocatable symbol, however, it may contain other operands and operators as well. A relocatable symbol can be modified by adding or subtracting a constant value.
    Examples for valid relocatable expression
    relocatable_symbol + absolute_expression
    relocatable_symbol - absolute_expression
    absolute_expression + relocatable_symbol
