Hi all,
We are developing on Keil uVision v4.74 for LPC2478 controller and using Keil ULinkPro for debugging.
We are using UART1 interface without Modem capabilities. Follwing is our initialization code:
//configure pin selections for UART1 // configure UART // enable power to UART PCONP |= (1<<MODBUS_OPTION2_POWER_BIT); // RX and TX interrupts U1IER = 0x3; // DLAB = 1 U1LCR = 0x83; U1FCR = 0x87; //Issue:actual value set is 0xC1 //Set Parity bit, Stop bit and baud rate according to application U1LCR &= 0x7F ; // DLAB = 0
The issue we are facing with the UART1 Fifo Control Register U1FCR is not setting the value correctly. U1FCR has following structure:
Bit 0 - FIFO Enable Bit 1 - Rx FIFO Reset Bit 2 - Tx FIFO Reset Bit 5:3 - Reserved Bit 7:6 - Rx Trigger Level 00 - Trigger level 0 (1 character or 0x01) 01 - Trigger level 1 (4 characters or 0x04) 10 - Trigger level 2 (8 characters or 0x08) 11 - Trigger level 3 (14 characters or 0x0E)
Everytime we set value 0x87(Trigger Level 2, Rx-Tx Fifo Reset, FIFO Enable), it is setting as 0xC1(Trigger Level 3,FIFO Enable)
Help needed seriously.
As I read in the User Manual of the controller, the said register U1FCR is a Write-Only register. That means my read access can be undefined?
"the said register U1FCR is a Write-Only register. That means my read access can be undefined?"
Yes.
Or, at least, that any value you read from that register is unrelated to the value that you wrote to it.
