I'm new with uVision and I need to create a project with the LPC2148 board. I have the uVision 5 and I downloaded the Legacy addon too but I still can't find the 2148 in the pack installer.
Please advise. Thank you.
With MDK-ARM V5 such ARM7 based µC are supported by the additional installation of the ARM7/9 Legacy-Pack: www2.keil.com/.../legacy
See also our "Getting Started" Guide at page 7: www2.keil.com/.../
I installed the legacy pack to the default directory but still I can't find it in the pack installer. Is it because I'm running the lite version?
Legacy-Pack supported devices are not listed in the Pack Installer (as they are not supported by a Device Family Pack).
During creating a new project, at "Select Device for Target", there is a pull-down menu, where you have to select "Legacy Device Database" (instead of "Software Packs") to get your device listed.
This "Legacy Support" you is comparable to the device support that was available with MDK-ARM V4.
Dear Community Members,
Couple of days back I was looking for article about how to use Keil uVision5 for LPC2148 ARM7 Microcontroller. I have't found any post online so decided to write step by step user guide in terms of blog. As there are couple of things which are tricky especially installation of software packs prior to create new project in Keil uVision5 to get things working.
www.binaryupdates.com/.../
I am happy to share this link with Keil community.
I wish you happy Programming
Thanking you
CHeers
Hi Umesh - this is a real helpful and well explaining document, thanks for sharing
