Hi everyone,
I am having trouble setting up the RTE in keil 5 for using the UART library(Driver_USART.h).I installed everything as recommended on the keil website (Keil.STM32NUCLEO_BSP.1.4.0).
The problem I have is when I try to select the USART in the RTE. I then click on resolve at the bottom of the window but I'm having the error:
Keil.MDKPro::USBHost require 2.00:CMSIS Driver:USB Host Install missing component
Do you have any idea how to resolve this ?
If I try to include manually "Driver_USART.h" the compiler says it is unable to find the file.
Thank you in advance for your help.
Maxime
