I have STM32F103 working on 8MHz. Use new ST HAL Driver (STM32CubeMX) + MDK-ARM v5.17? If I Init PWM on Ch1 Tim3
void MX_TIM3_Init(void) { TIM_ClockConfigTypeDef sClockSourceConfig; TIM_MasterConfigTypeDef sMasterConfig; TIM_OC_InitTypeDef sConfigOC; htim3.Instance = TIM3; htim3.Init.Prescaler = 0; htim3.Init.CounterMode = TIM_COUNTERMODE_UP; htim3.Init.Period = 9; htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; HAL_TIM_Base_Init(&htim3); sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL; HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig); HAL_TIM_PWM_Init(&htim3); sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET; sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig); sConfigOC.OCMode = TIM_OCMODE_PWM1; sConfigOC.Pulse = 1; sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH; sConfigOC.OCFastMode = TIM_OCFAST_DISABLE; HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_1); } ... // Start PWM HAL_TIM_PWM_Start_IT(&htim3, TIM_CHANNEL_1);
all working OK and output generate 125ns pulse on 800kHz (1.25us) If replace Start_IT with DMA version
uint32_t pData[1]={6}; HAL_TIM_PWM_Start_DMA(&htim3, TIM_CHANNEL_1,pData,1);
all working OK and output generate 700ns pulse on 800kHz (1.25us),but if use
uint32_t pData[16]={3,3,3,3,3,3,3,3,0,0,0,0,0,0,0,0}; HAL_TIM_PWM_Start_DMA(&htim3, TIM_CHANNEL_1,pData,16);
this genreate 375ns its OK but frequency is 400kHz (2,5us) If I trace and look on reg CCR1 I see 3,0,3,0,3,0,3,0,3,0,3,0,3,0,3,0 What's wrong, what's the problem? Why is inserted 0 between 3?
Data needs to be 16-bit wide like the register, not 32-bit, where high-order 16-bit words are zero, thus alternating 3/0
Also the period should be 9-1 for 72/9 = 8 MHz
Thanks you, with int16 you have true. Confused me function HAL_TIM_PWM_Start_DMA() where is the pointer on uint32_t.
"Also the period should be 9-1 for 72/9 = 8 MHz" Are you sure? But if I used 9 see Logic Analyzer in MDK-ARM http://imgur.com/XMX5Bmf
Whole thing is intended for driving WS2812B LED www.adafruit.com/.../WS2812B.pdf If I only Run PWM with
htim3.Init.Period =9; ... sConfigOC.Pulse = 6; ... HAL_TIM_Base_Start_IT(&htim3);
LED Flash White, but if use
htim3.Init.Period =9; // or 8 ... sConfigOC.Pulse = 0; ... uint16_t pData[25]={3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,6,6,6,6,6,6,6,6,0}; HAL_TIM_PWM_Start_DMA(&htim3, TIM_CHANNEL_1,(uint32_t*)pData,25);
in real hw is LED off on simulator see above
Complementing: I found another datasheet for WS2812B,it contains slightly different timings. http://goo.gl/oONsSQ The Chinese are great magician on datasheet. Maybe the problem is only the timing Log 1
Other additions
Period (ARR) = (Frequency of counter / required frequency)-1 Period (ARR) = (8MHz / 800kHz)-1 Period (ARR) = 9
I find problem
... // STM32F103ZE Clock 8MHz htim3.Init.Period = 9; ... // G G G G G G G G R R R R R R R R B B B B B B B B // 1 2 3 4 5 6 7 8 1 2 3 4 5 6 7 8 1 2 3 4 5 6 7 8 uint16_t pData[25]={3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,6,6,6,6,6,6,6,6,0}; // --------0------ --------0------ ------256------ STOP HAL_TIM_PWM_Start_DMA(&htim3, TIM_CHANNEL_1,(uint32_t*)pData,25);
and HW logic analyzer show this: http://imgur.com/QQclNlq
Instead of 16 ZERO bit is generate 19 ZERO bit and instead of 8 ONE bit is generate 9 ONE bit
Suspect someone in what could be the problem?
Sure? That would indicate a grave error on the part of the library API designer. If the expected data format is really an array of 16 bit integers, then it's badly wrong for the function argument to be of type (uint32_t *).
Casting a pointer to a different type besides (void *) and (uint8_t *) just to pass it to a function, as suggested here, is almost always either superfluous or very wrong.
