internal regulator for ADC of stm32l152
Hi
Can we use internal regulator for ref voltage of ADC of STM32L152? if you have experienced it please tel me how to do?
  • I am using
     ADC_TempSensorVrefintCmd(ENABLE);
    but it works with external vref
    my code is:
    void ADC_Init(void)
      ADC_InitTypeDef ADC_InitStructure;
    /* Enable ADC clock */
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    /* de-initialize ADC */
      ADC_DeInit(ADC1);
    /*  ADC configured as follow:
      - NbrOfChannel = 1 - ADC_Channel_9
      - Mode = Single ConversionMode(ContinuousConvMode disabled)
      - Resolution = 12Bits
      - Prescaler = /1
      - sampling time 192 */
        /* ADC Configuration */
      ADC_StructInit(&ADC_InitStructure);
      ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
      ADC_InitStructure.ADC_ScanConvMode = ENABLE;
      ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
      ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
      ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
      ADC_InitStructure.ADC_NbrOfConversion = 1;
      ADC_Init(ADC1, &ADC_InitStructure);
      /* ADC1 regular channel9 configuration */
      ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 1, ADC_SampleTime_192Cycles);
      ADC_DelaySelectionConfig(ADC1, ADC_DelayLength_Freeze);
      ADC_PowerDownCmd(ADC1, ADC_PowerDown_Idle_Delay, ENABLE);
      /* Enable ADC1 */
      ADC_Cmd(ADC1, ENABLE);
      /* Wait until ADC1 ON status */
      while (ADC_GetFlagStatus(ADC1, ADC_FLAG_ADONS) == RESET)
    uint16_t ADC_Supply(void)
      uint8_t i;
      uint16_t res;
    /* Initializes ADC */ ADC_Init();
    /* ADC1 regular channel 9 for VREF configuration */ ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 1, ADC_SampleTime_192Cycles);
    /* initialize result */ res = 0; for(i=4; i>0; i--) { /* start ADC convertion by software */ ADC_SoftwareStartConv(ADC1);
    /* wait until end-of-covertion */ while( ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC) == 0 ); /* read ADC convertion result */ res += ADC_GetConversionValue(ADC1); }
    /* de-initialize ADC */ ADC_TempSensorVrefintCmd(DISABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, DISABLE);
    return (res>>2); }
  • What values are you reading, and what do you expect to see?
    I'm not sure the ADC *uses* it as a reference as much as it allows you to determine the value of your supplied +VREF
  • Thanks for reply. I read by this command:
     battery_val=ADC_Supply();
    which calls
    I have not connected VREF+ to any power source in my board is there a way to connect it internally to vref of MCU by software?
  • Which part exactly are you using? Some devices have +VREF internally bonded to VDDA, and -VREF internally bonded to VSSA. On devices with VREF pins *you* have to connect them to the supplies yourself, in your design. I'm reasonably sure there is not a magic software setting, but try reading the manuals.
    Isn't VREFINT on CHANNEL 17?
    www.st.com/.../CD00277537.pdf
