Hi everyone,
I have an assembly code that I want to run in uVision4.
The .a51 code is as follows:
MOV A, #002H MOV R0, #040H MOV 040H, #001H XCH A, @R0 MOV R0, #050H MOV 050H, #0F0H XCH A, @R0 MOV R1, #060H MOV 060H, #0FFH MOV A, #0A0H XCH A, @R1 DB 0A5H END
When I run the code using the debugger in uVision4, it works properly and I can either step through the instructions and see the result on the registers and memory addresses, or run the whole program and see the final result. I can also use the uVision4 built-in debug functions to do the same.
The problem arises though, when I want to do the same stepping in my code, using some user-defined functions.
Here are my scripts and functions:
include tb_run_instructions.ini include test_instr_xch_a_at_ri.ini Func void test_instr(void) { test_instr_xch_a_at_ri(); return; }
Func void test_instr_xch_a_at_ri(void) { exec ("T 4"); tb_run_instructions(4); exec ("T 3"); tb_run_instructions(3); exec ("T 4"); tb_run_instructions(4); return; }
Func void tb_run_instructions(int inst) { printf("%d instructions were executed\n", inst); return; }
I run my code as:
In the command line of uVision I first include the main function, which includes the other required functions
include test_instr.ini
Then I run this function, which in turns run the other functions using
test_instr()
The problem is that only the first exec line in my function runs and the second and third execs shown in test_instr_xch_a_at_ri, do not run. Interestingly all the tb_run_instructions functions run and print their messages.
The final output in the command window of uVision4 is:
4 instructions were executed 3 instructions were executed 4 instructions were executed
But only the first four instructions were executed, and nothing happened afterwards.
Can you please help me to find out, where the problem is and how I can fix this, to run all required exec ("T x") in my script?
Cheers, Mostafa
Try to use the _sleep_ function between the exec function calls. See: http://www.keil.com/support/man/docs/uv4/uv4__sleep_.htm
Func void test_instr_xch_a_at_ri(void) { exec ("T 4"); tb_run_instructions(4); _sleep_ (10); exec ("T 3"); _sleep_ (10); tb_run_instructions(3); exec ("T 4"); _sleep_ (10); tb_run_instructions(4); return; }
where do you think the code goes at 'END"
Thanks all.
It turns out that I have been using the wrong type of functions here.
I should have used signal functions, which repeat operations in the background while µVision runs the target (assembly or C) program.
