Hi, After setting of the RCC registers like those in many examples in the web I found, I see that a toggling led does not match with the frequency of STM32f103RE. I have set the PLLmul to 9 and HSE devide value is 1. I used the code below to verify 72Mhz:
GPIOB->ODR|=0x8000; for(j=0;j<72000;j++){ for(i=0;i<1000;i++); } GPIOB->ODR&=0x7FFF; for(j=0;j<72000;j++){ for(i=0;i<1000;i++); }
the led period is about 9 sec.
RCC config is as follows:
void RCC_Configuration(void) { /*set RCC registers to default values RCC system reset*/ RCC_DeInit(); /*Enable HSE */ RCC_HSEConfig(RCC_HSE_ON); /*Wait till HSE is ready */ HSEStartUpStatus = RCC_WaitForHSEStartUp(); if(HSEStartUpStatus == SUCCESS) // SUCCESS { /*AHB= SYSCLK= 48 MHz, HCLK(AHB clock) = SYSCLK */ RCC_HCLKConfig(RCC_SYSCLK_Div1); /*PCLK2(APB2 clock)= AHB clock/2 = 24 MHz,PCLK2 = HCLK/2 */ RCC_PCLK2Config(RCC_HCLK_Div2); /*PCLK1(APB1 clock)= AHB clock/4=12 MHz, PCLK1 = HCLK/4 */ RCC_PCLK1Config(RCC_HCLK_Div4); //RCC_HCLK_Div4: APB1 clock = HCLK/4=12MHz /* set Flash delay clocks to 2 */ FLASH_SetLatency(FLASH_Latency_2); /* Enable Flash Prefetch Buffer*/ FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); /* PLLCLK = 8MHz * 9 = 72 MHz */ RCC_PLLConfig ( RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); /* Enable PLL */ RCC_PLLCmd(ENABLE); /* Wait till PLL is ready*/ while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) { } /* Select PLL as system clock source */ //Select PLLCLK as SYSCLK RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); /*Wait till PLL is used as system clock source */ while(RCC_GetSYSCLKSource() != 0x08) { } } /* Enable peripheral clocks --------------------------------------------------*/ /* GPIOA, GPIOB and SPI1 clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_SPI1, ENABLE); /* Enable GPIOC, GPIOD clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC| RCC_APB2Periph_GPIOD, ENABLE); }
How does a for loop written in C verify the processor speed? You have found a magic switch that controls the number of machine code cycles per iteration of the generated loop and that isn't affected by other project settings, integer type, volatile/nonvolatile, etc?
Ok, I get the point. thanks.
Output a divided down clock via a TIM pin, or MCO (PA8), and use an oscilloscope to verify the speed.
If possible use an LED connected to a TIM pin, and use Toggle or PWM mode to get a period/duty for the blinking you can verify by eye.
Timers, UART, SPI, PWM are great devices for generating some output that can be verified with an oscilloscope.
For some peripherial output, it's also possible to use a multimeter with frequency measurement function in case no oscilloscope is available.
And timers + LED + suitable long delays allows a w.a.t.c.h to be used to at least verify the frequency to with percent - and if the wrist w.a.t.c.h is within 99% of expected frequency then it's quite likely the actual frequency is correctly configured or within a +/- 1 error in the computation of the used divisor.
When will Keil finally learn how stupid it is to block posts that contains the word w.a.t.c.h?
