I get into this problem. I have a thread that process a message queue. One of my possible action on reception of a message is to open a file with the function fopen(). The file is located on a USB flashdisk and I am opening it with the option "w" : Logfile = fopen("U:\\Log.txt", "w");
I am using this file for logging. For testing purpose I am entering 200 values coming from ADC and then closing the file.
The first time the message is processed everything is fine. Now , the second time the message is received and process, the fopen() function is stalling for at least a minute then return with success and complete the following processing. I have noticed also that the connect and disconnect detection is not functioning normally too after the first fopen()/fclose().
Any ideas what could be the problem? Anything I need to know when opening, writing and closing a file?
Thank you
Which version of the File System are you using? What is your target hardware?
I am using the version 6.4.0 of the file system. I am working on 3 different boards : STM32F4-Discovery, STM32429i-Eval and MCBST32F400. The media is a 8 GB USB key connected on USB Full Speed port.
Hello Keaven,
I have tried with the following code on the 429I-Discovery board:
void Thread (void const *argument ) { static unsigned int result; static FILE *f; uint8_t i = 0; USBH_Initialize (0); while (1) { result = USBH_MSC_DriveMount ("U0:"); if (result == USBH_MSC_OK) { memset(fbuf, ++i, sizeof(fbuf)); f = fopen ("Test.txt", "w"); if (f != NULL) { LED_On(0); fwrite (fbuf, sizeof(fbuf), 1, f); fclose (f); LED_Off(0); } } osDelay (1); } }
Everything works as expected. Have you changed anything in the FS_Config_USB_0.h? What are your settings for the thread stacks (Default, Main, Total) in RTX_Conf_CM.c?
Kind regards,
Christopher
