Problem with SD card read/write
Hai..
Currently I am using the LPC1768 using keil uvision 4 and I am testing the example code from Keil "MCB1700_SD_File" to test SD card. While I build the code I got the below mentioned errors. Could you please tell me how to resolve the issue.
1] C:\Keil\ARM\RV31\INC\File_lib.c(45): error: #35: #error directive: all drives disabled in configuration
2} SD_File.c(518): error: #20: identifier "MMCFG" is undefined
3] SD_File.c(528): error: #165: too few arguments in function call
4] SD_File.c(541): warning: #223-D: function "mmc_read_config" declared implicitly
