Is there an easy way to copy/move/share projects?
I've discovered that sending a Keil project from one person to another is an absolute nightmare. All the paths are different, and even if you go through every single included file, there seem to be other paths that have no obvious way of being changed.
So, is there an easy way to do this? Some utility or internal function that lets you easily re-establish the paths when a project is copied to a new machine?
  • Says a man who's never used Eclipse/Atollic....
    Most of the stuff in the project is self-relative. How much stuff is outside the project folder, and can you maintain the directory depth?
    \LIBRARY\SRC
    \LIBRARY\INC
    \PROJECTS\PROJECT_X
    \PROJECTS\PROJECT_Y
    \PROJECTS\PROJECT_Z
    The include paths are specified in the C/C++ pane of the project options.
    Generally I can just zip up a project, or copy-n-paste a directory to clone it. I can right click components in a broken project and change the path to them.
    If I've totally mutilated the project, I can pull the file in a text editor and search-n-replace Path X with Path Y, or change the relative depth \..\
  • Wow, I never realized the project file was a text file. That does make things a lot easier.
    However, while I can adjust the paths of the files included in the project, within Keil, if I expand any of them, most of the files which are shown that the expanded file depends on (e.g. core_cm4.h, stdint.h, etc...) have exclaimation marks on the icons.
    So something still isn't being addressed by this.
