Library CODE area problem
My code supposed to use ECODE memory region only.
I've noticed that several issues are related to this requirement:
- placing "code" directive in C places the function in CODE only area.
- if code uses library ( not explicitly specified ) the code is placed
in CODE area. This feature violates my requirements.
Do You know how to places the library code in ECODE area?
I'm using library long multiplication function ( input parameters
in registers, as well as output).
Does anyone have any hint for MUL function in KEIL A51 or long numbers (32 bits) ?
Regards
Robert
