Hello everybody, I need help with my school project. My task is to create a program on C8051F330 microchip using uVision. The program should regulate RPM of a pc fan, using PWM (4 pin (wire) PC fan, I have to generate a PWM signal on the fourth wire to regulate it). Since I dont have any opportunity to try my program at home, I want to ask for your help, if it will work or where do I make mistakes. Ok so here is my program:
#include <c8051f330.h> #include <stdio.h> extern void Init_Device(); #define SYSCLK 24500000 #define CLKDIV 12 sbit button_increaseRPM=P1^1; sbit button_decreaseRPM=P1^2; float f, fp; unsigned int reg, required_RPM, current_RPM, save_DutyCycle, count_impulses; void main(void) { Init_Device(); TI0 = 1; save_DutyCycle = 0; required_RPM = 400; ///minimal RPM printf("Increase/decrease RPM with buttons\n"); while(1) { if (button_increaseRPM == 0x02) { required_RPM++; } if (button_decreaseRPM == 0x04) { required_RPM--; } f = save_DutyCycle; //return duty cycle value to f, because of later overwritng in program //compare the required RPM with current RPM if (required_RPM != current_RPM) { if(current_RPM < required_RPM) { save_DutyCycle++; //increase duty cycle of PWM f = save_DutyCycle; f /= 100; f = (1 - f) * 256; PCA0CPH0 = f; } else { save_DutyCycle--; //decrease duty cycle of PWM f = save_DutyCycle; f /= 100; f = (1 - f) * 256; PCA0CPH0 = f; } } } } void INT0 (void) interrupt 0 //counting impulses { count_impulses++; } void TMR2INT (void) interrupt 20 // 20 ms , check counted impulses { TF2H = 0; // Clear interrupt flag for timer 2 reload 16 bit mode current_RPM = ((count_impulses/0.02)/2); //timer2 20ms, and 2 impulses from the fan per rotation count_impulses = 0; // }
Every other settings are in the config created with Configuration Wizard 2 (Silicon laboratories).
Thank You for your help!
post at http://community.silabs.com/ you have a better chance where responders do not have to wade through the spam
Thanks for the advice.
