TCPnet SMTP Inconsistency - Debug Logs
Previously I had posted about inconsistent SMTP client issues using the TCPnet library (http://www.keil.com/forum/56776/). The consensus of the forum was to get debug information and post it and so I have done that below. The debug library is configured to print out any error conditions and a full debug on the SMTP client itself.
As far as hardware goes the Ethernet driver is an ENC28J60 and the MCU is an LPC2148.
One of three things happens repeatedly: it either works and sends and email, or it fails to get IP, or it just 'fails to send'.
Failed to Send (SMTP callback function returns with the code EVT_EVENT_ERROR)
SMTP:Init Client
SMTP:Connect Client
SMTP: Server: 74.220.215.246
SMTP: Port  : 26
TCP-ERR:Socket 1, No Retries left
SMTP-ERR:Client stop, Socket aborted
Fails to get IP Address via DHCP
SMTP:Init Client
Sends Correctly
SMTP:Init Client
SMTP:Connect Client
SMTP: Port  : 26
******** TCP-ERR:Socket 1, Unknown frame received ******* (this line only occurs sometimes but the sending still works properly)
SMTP:Socket connected
SMTP:*** Processing frame ***
SMTP: Received length: 181 bytes
SMTP: Server is ready
SMTP: Sending: EHLO lookout
SMTP: Received length: 138 bytes
SMTP: EHLO acked, ESMTP mode
SMTP: Start Authentication
SMTP: Sending: AUTH LOGIN
SMTP: Received length: 18 bytes
SMTP: Sending: d2VzbGV5QGxvb2tvdXRwb3J0YWJsZXNlY3VyaXR5LmNvbQ==
SMTP: Sending: d2VzbGV5MTIzNA==
SMTP: Received length: 30 bytes
SMTP: Authentication successful
SMTP: Sending: MAIL FROM: <email@example.com>
SMTP: Received length: 8 bytes
SMTP: Server acknowledge
SMTP: Sending: RCPT TO: <email2@example.com>
SMTP: Received length: 14 bytes
SMTP: Sending: DATA
SMTP: Received length: 56 bytes
SMTP: Sending 'Message Body'
SMTP: Received length: 28 bytes
SMTP: End of Message acknowledge
SMTP: Sending: QUIT
SMTP: Received length: 48 bytes
SMTP: Client done, close socket
