I am relatively new to the Keil / ARM development environment though have been programming microcontrollers and C for a few years now (though only in an amateur capacity :).
I am using sprintf to format a string for display on an LCD (though the same thing happens when sending the string over the serial port as well) and am getting a warning:
warning: argument of type "unsigned char *" is incompatible with parameter of type "char *restrict"
Everything works ok when I ignore this warning but ignoring these warnings doesn't sit well (especially as I don't really understand it). I get that "restrict" is a new keyword feature in C99 to enable compiler optimisations and it probably doesn't matter too much for the simple applications I am creating, but I would like to know if this is implemented in the ARM compilation toolchain and, if so, how I can use it. A snippet of my code is below:
// initialise some local values and the display buffer uint32_t val; static unsigned char disp_buffer[21]; // read the global variables to the local values val = global_val; // do string formatting before lcd display sprintf(disp_buffer, "Value: %4d", val); GLCD_DisplayString(6, 0, 1, disp_buffer);
Thanks for any help you can give,
Alex
signed vs unsigned? If you don't like warnings, use a cast and be explicit.
Thanks for your help. I don't think that is it - if I declare my buffer as:
I just get the warning:
warning: #167-D: argument of type "char *" is incompatible with parameter of type "unsigned char *"
instead!
Then that suggests:
// initialise some local values and the display buffer uint32_t val; static char disp_buffer[21]; // read the global variables to the local values val = global_val; // do string formatting before lcd display sprintf(disp_buffer, "Value: %4d", val); GLCD_DisplayString(6, 0, 1, (unsigned char*)disp_buffer);
Thanks Dan - but I'm afraid I still get the warning:
Cheers,
Thanks Dan - but I'm afraid I still get the warning: But do you get it regarding the same source code line than the other one? I don't think so.
