Simulator C8051F12x: Timer2 in output toggle mode.
I launch the program "F12x_Timer2_16bitToggle.c" from the folder with examples of Silabs ( C:\Silabs\MCU\Examples\C8051F12x_13x\Timers, but does not work as described: No bits in port0 is not changed.
// Program Description:
// This program presents an example of use of the Timer2 of the C8051F12x's in
// 16-bit output toggle mode.
// It uses the 'F120DK as HW platform. This example code counts in timer2 until
// it overflows. At this moment the T2 output is toggled.
// Pinout:
//    P0.0 -> T2 toggle output
// How To Test:
// 1) Load the F12x_Timer2_16bitToggle.c
// 2) To change the toggling rate modify TOGGLE_RATE value (0 to 255 -> msec)
// 3) Compile and download the code
// 4) Run
// 5) Check the P0.0 pin (T2)
// FID:            12X000001
// Target:         C8051F12x
// Tool chain:     KEIL C51 7.20 / KEIL EVAL C51
// Command Line:   None
// Release 1.0
//    -Initial Revision (CG)
//    -09 NOV 2005
// Includes
#include <c8051f120.h>                 // SFR declarations
// Global Constants
#define TOGGLE_RATE              1L  // TOGGLE Rate of P0.0 in msec (255 max)
// The timer is operating from a 24.5MHz (SYSCLK) with a prescaler of 1:12,
// therefore the frequency is of 255KHz
#define AUX0                    - (TOGGLE_RATE)*256
#define AUX1                    AUX0&0x00FF
#define AUX2                    ((AUX0&0xFF00)>>8)
#define TIMER2_RELOAD_HIGH       AUX2 // Reload value for timer2 high byte
#define TIMER2_RELOAD_LOW        AUX1 // Reload value for timer2 low byte
// Function Prototypes
void PORT_Init (void);                 // Port initialization routine
void TIMER2_Init (void);               // Timer0 initialization routine
// main() Routine
void main (void)
   WDTCN = 0xde;                       // Disable watchdog timer
   WDTCN = 0xad;
   TIMER2_Init ();                     // Initialize the timer2
   PORT_Init ();                       // Init Ports
   EA = 1;                             // Enable global interrupts
   while (1);                          // Loop
// Initialization Subroutines
// PORT_Init
// This function configures the crossbar and GPIO ports.
   char SFRPAGE_SAVE = SFRPAGE;        // Save Current SFR page
   SFRPAGE = CONFIG_PAGE;              // set SFR page
   XBR1 = 0x20;                        // T2 available in the pins
   XBR2 = 0x40;                        // Enable crossbar
   P0MDOUT = 0x01;                     // Enable P0.0 as output
   SFRPAGE = SFRPAGE_SAVE;             // Restore SFR page
// TIMER2_Init
// This function configures the timer2 as 16-bit auto-reload.
// It Uses the internal osc. at 24.5MHz/8 with a 1:12 prescaler.
// At each overflow the P0.0 is toggled.
void TIMER2_Init(void)
   SFRPAGE = TMR2_PAGE;                // Set SFR page
   TMR2CF = 0x02;                      // output enabled, SYSCLK/12
   RCAP2L = TIMER2_RELOAD_LOW;         // Reload value to be used in Timer2
   RCAP2H = TIMER2_RELOAD_HIGH;
   TMR2CN = 0x04;                      // Enable timer2 in reload mode
// End Of File
