(RTX,STM32) How to use the serial port?
Hi everybody,I'm learning to use RTX RTOS,but I don't know how to use the USART of STM32 in RTX.
Do you have this example? Thank you very much!
  • But do you know how to use the USART without RTX?
    Because in that case it's just a question of signalling a producer thread if the USART code is running low on data to send. And signal a consumer thread if you have received data - either by sending the data directly to the thread or by storing in a buffer and setting an event that data is available. So same-same as for other USART + OS combinations.
