Interrupt Register Bank Usage
I created a timer 0 interrupt handler:
void Timer_0_Interrupt(void) interrupt INTERRUPT_TIMER_0 using 1
I noticed that the compiler created instructions with absolute register access. Please confirm that I must also specify either "#pragma REGISTERBANK(1)" or "#pragma NOAREGS". Otherwise the code will use register bank 0 for the absolute register instructions.
  • Please confirm that I must also specify either "#pragma REGISTERBANK(1)" or "#pragma NOAREGS". Otherwise the code will use register bank 0 for the absolute register instructions.
    You do not, "using 1" makes the routine (ISR or other) use register bank 1 throughout.
  • As Erik points out, the 'Using 1" tells the compiler to switch register bank from 0 to register bank 1 on entering the ISR routine. The compiler creates a prolog to store some information on a 'stack' not in the registers. On exiting the ISR, the code pops the PC address from the stack and switches back to register bank 0.
    Bank 0 is the default register bank. Most of the time register bank 0 is used to pass args to called sub-routines. Regs 7 and 6 for the first arg (int) and then regs 5 and 4 for the second arg (int) and then regs 3 and 2 for the third args. Any other args are passed via absolute memory addresses. Regs 1 and 0 are not used for passing args. Of course, args cannot be passed into an ISR and any values in reg bank 0 would remain until the bank becomes active once again.
    Never, never, never write Using 0! You give the compiler/linker permission to write over Register Bank 0 without saving any of the registers.
    It's in the book!
    Bradford
