Hello all,
I have written a code with PLL Initialization from 12MHz external crystal oscillator, configured the PLL to lock to 288Mhz with M and N values as 12 and 1. FCCO = (2 * M * Fin)/N = (2 * 12 * 12MHz)/1 = 288MHz CCLK = FCCO/CCLKDIV = 288/6 = 48 MHz
Configured the CPU Clock divider to 6 and USB clock Divider to 6, so that the CPU runs at 48MHz. The code for it is shown below.
void ConfigurePLL ( void ) { DWORD MValue, NValue;
if ( PLLSTAT & (1 << 25) ) { PLLCON = 1; /* Enable PLL, disconnected */ PLLFEED = 0xaa; PLLFEED = 0x55; }
PLLCON = 0; /* Disable PLL, disconnected */ PLLFEED = 0xaa; PLLFEED = 0x55;
SCS |= 0x20; /* Enable main OSC */ while( !(SCS & 0x40) ); /* Wait until main OSC is usable */
CLKSRCSEL = 0x1; /* select main OSC, 12MHz, as the PLL clock source */
PLLCFG = PLL_MValue | (PLL_NValue << 16); PLLFEED = 0xaa; PLLFEED = 0x55;
CCLKCFG = CCLKDivValue; /* Set clock divider */
#if USE_USB USBCLKCFG = USBCLKDivValue; /* usbclk = 288 MHz/6 = 48 MHz */ #endif
while ( ((PLLSTAT & (1 << 26)) == 0) ); /* Check lock bit status */
MValue = PLLSTAT & 0x00007FFF; NValue = (PLLSTAT & 0x00FF0000) >> 16; while ((MValue != PLL_MValue) && ( NValue != PLL_NValue) );
PLLCON = 3; /* enable and connect */ PLLFEED = 0xaa; PLLFEED = 0x55; while ( ((PLLSTAT & (1 << 25)) == 0) ); /* Check connect bit status */ return; }
Now i had made the below line from SCS |= 0x20; /* Enable main OSC */ to SCS |= 0x00; /* Disable main OSC */ and made the clock source to PLL as Internal 4Mhz Oscillator. CLKSRCSEL = 0x0; /* select main OSC, 12MHz, as the PLL clock source */
So now the PLL calculations with the same PLL M and N values are FCCO = (2 * 12 * 4MHz)/1 = 96MHz CCLK = 96/6 = 16MHz But the PLL output frequency should be in the range of 275 to 500MHz. Here it is 96Mhz so it should not lock. But my code is working at 16Mhz with PLL enabled and is working fine. Can the PLL be locked with that range?
Can anyone give me an explanation.
You can write a post and include some badly formatted code and still miss the basic information.
You didn't think it necessary to state the actual processor you're using?
Clever.
Sry to mention, The controller i have used is LPC2368
A PLL can sometimes lock on an overtone (or undertone) if the input frequency happens to be maybe twice or half the frequency it should normally use.
Just that it then will not produce the correct output frequency even if it has locked and produces a stable frequency.
Anyway - why do you care? If you are withing the specified range, then the processor manufacturer gives you a promise that it should work. If you are outside, then they don't care if it works or not because it isn't supported. But not supported doesn't mean "doesn't work".
