Issue with I2C communication continuation
below is the I2C.h file ,continuation for the EEPROM I2C code
#ifndef __I2C_H
#define __I2C_H
/* If I2C SEEPROM is tested, make sure FAST_MODE_PLUS is 0.
For board to board test, this flag can be turned on. */
#define FAST_MODE_PLUS 0
#define I2C_PORT_NUM 3
#define BUFSIZE 0x80
#define MAX_TIMEOUT 0x00FFFF
static LPC_I2C_TypeDef (* const LPC_I2C[I2C_PORT_NUM]) = { LPC_I2C0, LPC_I2C1, LPC_I2C2 };
#define I2CMASTER 0x01
#define I2CSLAVE 0x02
#define PCF8594_ADDR 0xA0
#define READ_WRITE 0x01
#define RD_BIT 0x01
#define I2C_IDLE 0
#define I2C_STARTED 1
#define I2C_RESTARTED 2
#define I2C_REPEATED_START 3
#define DATA_ACK 4
#define DATA_NACK 5
#define I2C_BUSY 6
#define I2C_NO_DATA 7
#define I2C_NACK_ON_ADDRESS 8
#define I2C_NACK_ON_DATA 9
#define I2C_ARBITRATION_LOST 10
#define I2C_TIME_OUT 11
#define I2C_OK 12
#define I2CONSET_I2EN (0x1<<6) /* I2C Control Set Register */
#define I2CONSET_AA (0x1<<2)
#define I2CONSET_SI (0x1<<3)
#define I2CONSET_STO (0x1<<4)
#define I2CONSET_STA (0x1<<5)
#define I2CONCLR_AAC (0x1<<2) /* I2C Control clear Register */
#define I2CONCLR_SIC (0x1<<3)
#define I2CONCLR_STAC (0x1<<5)
#define I2CONCLR_I2ENC (0x1<<6)
#define I2DAT_I2C 0x00000000 /* I2C Data Reg */
#define I2ADR_I2C 0x00000000 /* I2C Slave Address Reg */
#define I2SCLH_SCLH 0x00000080 /* I2C SCL Duty Cycle High Reg */
#define I2SCLL_SCLL 0x00000080 /* I2C SCL Duty Cycle Low Reg */
#define I2SCLH_HS_SCLH 0x00000008 /* Fast Plus I2C SCL Duty Cycle High Reg */
#define I2SCLL_HS_SCLL 0x00000008 /* Fast Plus I2C SCL Duty Cycle Low Reg */
please help me .
