extInt doesn't start Timer, LPC2387
Using the following setup: µC: LPC2387 dev. tool: Keil µVision4 RL-FlashFS file system (SD card) runs on the µC.
I've got the 2 following problems:
Problem 1:
My code is supposed to execute EXTINT0_IRQHandler() on every rising edge of a 1Hz square wave present at pin P2.10_EINT0.
Then, after a delay defined by T1MR0, T1_IRQHandler() is to be executed.
The expected behaviour is therefore an execution frequency of EXTINT0_IRQHandler() of 1Hz and the same execution frequency for T1_IRQHandler()
with a delay defined by T1MR0.
Although a correct execution frequency of EXTINT0_IRQHandler() is verified with a blinking LED, T1_IRQHandler() is not reached.
After several minutes however, LED 5 eventually turns on.
Do you have any idea?
Problem 2:
The µC doesn't start correctly after reset when the interrupt pin was low.
Any idea? This would be a great help.
Thanks in advance!
void init()
        int toggle_extint=0;
        // init. external interrupt
        PINSEL4 |= (1<<20);
        EXTMODE =(1<<0);
        EXTPOLAR =(1<<0);
        VICVectAddr14 = (unsigned long)EXTINT0_IRQHandler;
        VICVectPriority14=14;
        VICIntEnable |= (1<<14);
        // init. timer 1; don't start
        T1MR0         = 20;
        T1MCR         |=(1<<MR0I)|(1<<MR0R);
        T1TCR         = 0;
        VICVectAddr5  = (unsigned long)T1_IRQHandler;
        VICVectPriority5  = 15;
        VICIntEnable  |= (1  << TIMER1);
__irq void EXTINT0_IRQHandler(void)
        EXTINT = 1;
        // LED blinks -> interrupt is executed as expected
        if(toggle_extint)
                toggle_extint=0;
                led_on(2);
        else
                toggle_extint=1;
                led_off(2);
        T1TCR       = 1;                    // timer 1 is enabled here!
        IOSET0  = (1 << 16);
        VICVectAddr=0;
__irq void T1_IRQHandler (void)
        led_on(5);              // PROBLEM: LED never switches on, code is never reached!
        T1TCR       = 0;                    // Timer1 disable
        // do something...
        T1IR        = 1;                    // Clear interrupt flag
        VICVectAddr = 0;
  • Hi everybody.
    My 2nd problem is solved so far.
    A "low" on P2.10 (EINT0) at reset will start the bootloader...
    ok. (thats more a feature than a bug, I know.)
    But what do I have to keep in mind, to start Timer1 from this EINT0?
    again:
    with that code given, I never reach the "T1_IRQHandler" and I dont know why.
    Thank you in advance!!
