C8051F120 extended Hex record
Hi ,
I am using C8051F120 mcu for my application software. This software has 3 hex files because in this i have used code banking. I have use Bank 0,1,2,3. Now I am using JTAG for downloading code.
Now I want to write code for boot loader for this MCU. So I have some queries to implement it.
1.When I have created bank setting in Keil project then 3 files created those not .hex. Those are .HO1,.HO2,.HO3.
2. While downloading code through there is option to select bank number.
3. Now I want to download code through hyper terminal.
My quesions are
1. How can I give this bank selection through hyper terminal because in datasheet exact address mapping not given for each bank ?
2. There is setting in keil for extended hex record how it can set and use in code?
Please reply asap.
Regards ,
Prashant.
  • Thank you every body who helped, I have solved my problem. Especially I must thank the man with no name. Without your personal assistance I do not think it would be good to fix.
    The biggest issue was that I did not know to set RashGumL flag
    to 1 in order to tell the line i was sending an ack bit, I saw in the
    documentation that it said it was "normally" set to one, but did
    not understand the importance.
    Have a great day!
