I am facing a problem in vxWorks. The problem is:
I hava a pragma packed structure like below:
struct C { float aaa; float bbb; } __attribute__((__packed__)) var3;
struct B {
float aa; float bb; char cc; struct C varC[10]; } __attribute__((__packed__)) var2;
struct A {
float a; float b; char c; struct B varB; } __attribute__((__packed__)) var1;
The main function looks like below:
int try() {
struct A varA;
printf("\n sizeof(A)=%d",sizeof(struct A)); printf("\n sizeof(B)=%d",sizeof(struct B)); printf("\n sizeof(C)=%d",sizeof(struct C));
return 1; }
Then, the output is:
sizeof(A)=98 sizeof(B)=89 sizeof(C)=8
So, the output comes correctly as the structure A,B and C are all pragma packed.
But the problem is coming when I am trying to assign some floating point value to the variable 'aa' and 'bb' of structure B.
So the modified main function looks like this:
varA.a=1.0; /* works fine */ varA.b=2.0; /* works fine */ varA.c='A'; /* works fine */
varA.varB.aa=10.0; /* problem : gives alignment exception */ varA.varB.bb=20.0; /* problem : gives alignment exception */ varA.varB.cc='B'; /* works fine */
Now, if I change the data type of 'aa' and 'bb' to int...then it works fine.
plz help.
What has this got to do with Keil?
"The Keil Discussion Forum is an open forum where you may post questions and comments about Keil products."
If you create packed structures on an ARM7 or ARM9 that have internal alignments that violate the processor requirements, it is your responsibility to safely unpack them, not the compiler's.
