stm32f TIM7 doesn't count
Hello All,
I have a stm32f303 micro, and I am using Keil's uVision4.
I am running at 8 Mhz.
The function below is being called ok.
But for some reason when I look at TIM7 CNT I don't have anything?
Just 0x00, no up count?
void TimerInit ( void )
// 976 Hz 15625 Hz
RCC->CFGR = 0x38F0; //(HCLK/16), (SYSCLK/512), (HSI Selected clock at SW)
RCC->CR = 0x01; //HSI enabled
RCC->APB2ENR = 0x01; //Enabling System Clock enabled
RCC->APB1RSTR = 0x20; //Reseting TIM7 1=reset, 0=no-action
RCC->APB1ENR = 0x20; //Enabling TIM7 Clock
TIM7->CR1 = 0x85; //Clock enabled, URS enabled
TIM7->SR = 0x00; //Clearing the UIF (Update Interrupt Flag)
TIM7->DIER = 0x01; //Enabling the interrupt for the overflow of the Timer 7
TIM7->EGR = 0x01; //Event Generation Register to Update Registers
TIM7->ARR = 0x8E; //The value required for the Event to occur, Counter value.
Does anyone have any ideas on what to check?
Any suggestions?
I really appreciate the help,
Jim
  • Passing numeric values to registers is a bad idea my friend, Why you don't use the standard peripheral library that comes with every STM32 microcontroller?
    For example this is an initialization function for TIM4 in a STM32F4xx
    void TIM4_Config(void){
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    /* Enable SYSCFG clock */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
    /* Enable the TIM4 global Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    //Timer clock
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
    /* Time base configuration */
    // funcion que inicializa la estructura con sus valores por defento
    TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
    TIM_TimeBaseStructure.TIM_Period = 9999; // valor hasta el cual contara el timer
    TIM_TimeBaseStructure.TIM_Prescaler = 99;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //Modo de conteo
    TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
    /* TIM Interrupts enable */
    TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE);
    TIM_Cmd(TIM4, ENABLE);
    the code is perhaps longer but much more clean.
    Regards
  • Hello,
    I am trying the STD Library but I don't have the right header files.
    What where the header files that you are using for the timer init?
    Thankyou for the help,
    Jim
  • Well, I tried the code that you used for the TIM4 and I have it compiling now.
    When I run it and I look at the counter register I don't see any incrementing?
    Is that normal? Is there something that needs to be set in software?
    I am using uVision4 by Keil.
    Thankyou,
    Jim
